Strobe question
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Zenith750-List
KM Heide
PostPosted: Mon Nov 17, 2008 10:54 pm    Post subject: Strobe question Reply with quote
Members:
When you completed the tail section did you have to include wires for the rear rudder light? I see the kit adds this on the finishing kit but would seem easier to attach when you are building. Thoughts?
KMHeide
- The Matronics Zenith750-List Email Forum -
http://www.matronics.com/Navigator?Zenith750-List
Stefan
PostPosted: Tue Nov 18, 2008 10:38 am    Post subject: Re: Strobe question Reply with quote
Good point.
It was not mentioned at the "rudder" workshop. However, it is not that difficult to do even after you built the rudder. At this point, building the kit, most folks have a real problem with the skin for the elevators. It appears to be not only a problem with the manual but also with the plans. That is a little scary. As for the wings, no manual is available, only plans. Hope that will change soon. On the other hand, builder support is excellent. ZAC responds within a day for questions and support. Great job!
Stefan
PS. The 750 will be beautiful plane.
Rhino
PostPosted: Mon Dec 15, 2008 11:13 am    Post subject: Re: Strobe question Reply with quote
I asked Roger when I was at the workshop. He said it was a piece of cake to just do it later.
Bob Simmons
CH 750
N750TN (reserved)
Rhino
PostPosted: Tue Dec 16, 2008 9:56 am    Post subject: Re: Strobe question Reply with quote
And I just noticed that Zenith has a sense of humor in their tail position light assembly manual.
Measure up 160mm from the lower trailing edge. This is where the fiberglass bracket will be position, unless your Rudder has a dent on the trailing edge at a different location. Using the bracket to cover up the dent.
So in other words 'it goes here unless you want to use it to cover a dent'.
The grammar errors are those of Zenith.
Bob Simmons
CH 750
N750TN (reserved)
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Zenith750-List All times are GMT - 8 Hours
