Dick Maddux
Posted: Sat Dec 20, 2008 5:48 am Post subject: Engine out in experimental aircraft |
Lowell if you decide to make a spreadsheet for experimentals( other aircraft not included) you can count me in for two engine failures. One was in a "Der Jaeger"(biplane) that one I put back on the runway with no damage. The other was a Pitts which I ended up putting upside down in a field (it was destroyed) Both happened on take off.
Dick Maddux
Fox 4
Pensacola ,Fl
A 100000075x1215047751x1200957972/aol?redir=http://www.freecreditreport.com/pm/default.aspx?sc=668072%26hmpgID=62%26bcd=DecemailfooterNO62"> See yours in just 2 easy steps!
