wb2ssj(at)frontiernet.net Guest
Posted: Thu Dec 25, 2008 7:29 am Post subject: installing the cowl |
Its Christmas and I got the day to work on my plane. Has anyone have a easy way to remove and install the lower cowl by ones self with out scratching the devil out of it? Suggestions welcome.
MERRY CHRISTMAS EVERYONE
Tex
| | - The Matronics Lightning-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
IFLYSMODEL(at)aol.com Guest
Posted: Thu Dec 25, 2008 9:31 am Post subject: installing the cowl |
Hey Tex: I remove mine by placing my rolling footstool under the front, and gently lowering it down to the stool. I take out the screws, un hook the two air hoses, then the hinge pins on the oil cooler (while holding the front at the last bit) and then wiggle/work it down as required. I have removed it about 4 times and still have not scratched it (knock on my hard head)
Lynn Nelsen
Merry Christmas to you too.
In a message dated 12/25/2008 10:29:46 A.M. Eastern Standard Time, wb2ssj(at)frontiernet.net writes:
| Quote: | Its Christmas and I got the day to work on my plane. Has anyone have a easy way to remove and install the lower cowl by ones self with out scratching the devil out of it? Suggestions welcome.
Tex
://www.matronics.com/contribution">http://www.matronics.com/contribution
href="http://www.matronics.com/Navigator?Lightning-List">http://www.matron.matronics.com/">http://forums.matronics.com
One site keeps you connected to all your email: AOL Mail, Gmail, and Yahoo Ma=emlcntaolcom00000025">Try it now.
pennington(at)q.com Guest
Posted: Thu Dec 25, 2008 10:15 am Post subject: installing the cowl |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Hello Tex
First, it is easier if you cut a notch in the lower fiberglass cowl at the trailing edge to easily fit around the nose gear leg and provide clearance when installing and removing it. I found this out after I already scratched it. Look at Nick's bottom cowl. This mod is not in the manual. I cut out a notch about 2.5" square.
Second, I wrap a towel around the nose gear faring and pant. It helps to prevent scratches.
Third, I installed a length of twisted wire around the top engine mounts, (one on each side) so I could slip the wire through a quarter turn fastener hole in the lower cowl to support it while I remove the four lower screws. Then, I support the bottom of the cowl with my right knee and pull out the twisted wire so the cowl rests on my knee and carefully lower it to the ground.
Sound like a lot of maneuvering....it is. But, after you do it a few times, it gets easier. Oh, and don't forget to remove the clamps for the oil cooler inlet and air ducts.
Have a great holiday.
Gary Pennington
LIGHTNING AUSTRALIA
Joined: 02 Dec 2008 Posts: 11 Location: Kingston SE AUSTRALIA
Posted: Thu Dec 25, 2008 8:27 pm Post subject: installing the cowl |
HI Tex , If you go to a 2nd hand shop & get an old telescopic office chair take the back off & wheel it under the cowl. Adjust the height , take out the cowl screws & wheel it out, works just as good putting it back on. A simple one person operation.
We use it all the time on our build projects.
Dennis Borchardt. Lightning Aircraft Australia.
LIGHTNING AUSTRALIA
Posted: Thu Dec 25, 2008 8:46 pm Post subject: installing the cowl |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
