hammer408(at)comcast.net Guest
Posted: Sat Dec 27, 2008 1:53 pm Post subject: D-Sub Pins |
Bob:
Looking thru your archives, I see that one can use D-Sub's are wiring
connections: I.E. - joining 2 wires together, rather than use butt splices,
solder seal, etc....
So my question is:
1- Rather than soldering my Mic & Phone jack wires directly to my jack
outlets, can I solder leads, then use D-Sub pins to join to the leads to the
amin wires?
2- Can I also use these D-Subs for splicing shielded wire: 22 awg wire?
I can see al lot of uses for these D-subs, amazing !!!
Henry
Posted: Sun Dec 28, 2008 6:54 am Post subject: D-Sub Pins |
At 06:55 PM 12/27/2008, you wrote:
Quote: |
<hammer408(at)comcast.net>
Bob:
So my question is:
amin wires?
If you wish. What is the advantage? You've increased parts
count and total numbers of joints. Are these jacks likely
to be removed and replaced as part of a maintenance activity?
If you need to break a wire bundle during routine maintenance
then it's best to use a complete mated pair of d-sub connectors
as opposed to individual pin-pairs under heatshrink.
Quote: | 2- Can I also use these D-Subs for splicing shielded wire: 22 awg wire?
They ARE a legacy technology with features that
can address design-goals that are peripheral to
or sub-sets of the original ideas. But as a general
rule we try to MINIMIZE parts count and $time$ to
install wires for best reliability and lowest cost
of ownership. Splicing of wires is best made with
permanent joining technologies (crimp/solder) unless
there is an over-riding interest in future maintenance
activities made simple by the use of de-mateable
splices whether grouped as connectors or individual
pins.
Keep in mind too that the single pin-pairs under
heat-shrink are VERY vulnerable to de-mating under
tension. Use this technique with careful attention
to support of strands either side of the splice to
prevent tugging on the joint.
( -Thomas Paine 1776- )
longg(at)pjm.com Guest
Posted: Mon Dec 29, 2008 8:14 am Post subject: D-Sub Pins |
Henry,
I too use them for various connection points, especially those that may
need to be separated at some point. They are indeed handy. Rather than
get into some fancy connector I butt the male/female pins together,
shrink wrap the whole mess - done. Make sure your shrink wrap is well
done so they don't pull apart. If you need to take them apart use a p
blade or other against the connector to remove the shrink wrap. Don't
touch the wire with the knife.
If you have a connection that needs to come apart regularly, just go to
RS and get two 9/15 pin connectors to join the two. You will need two
4/40 bolt/nuts to keep the DB connectors together. Use a bit of
lock-tite or epoxy on bolts to keep them from separating.
The only thing you need to obey are the amperage limits on the pins. The
rest is up to your imagination.
If you're always in a hurry like me, get your stuff from L-com. Great
prices, incredible service (get your own rep if you like) and very fast
shipping. I get most stuff within a day or two of ordering. They will
also make any custom cable you need.
http://www.l-com.com/
Glenn
