hammer408(at)comcast.net Guest
Posted: Wed Dec 31, 2008 10:03 am Post subject: Hour Meter/Oil Pressure Wiring |
Bob:
I'm in a bit of a quandry regarding wiring my Hobbs Meter, Oil Pressure Switch and Low Oil Pressure Warning light !! I've printed out the Drawings from B & C and found one of your drawings regarding this wiring, however, before I went to order my transducer from B&C, I checked with Advanced Flight Systems to make sure that B&C's Oil Pressure transducer would work with the AFS 4500 EFIS / Engine monitor.......the answer was NO....I had to purchase theirs.
They told me that their transducer had a single terminal (for their signal wire) that connects to their wiring harness: NOT a 3 terminal arrangement (S-I-P) configuration like B&C's....
SO, can you give me some suggestions on how I can wire my Hour Meter, Oil Pressure Warning Light given that there is only 1 terminal ??
Any help or suggestions appreciated.
Henry
Posted: Wed Dec 31, 2008 10:35 am Post subject: Hour Meter/Oil Pressure Wiring |
Henry,
I'm not Bob, I didn't stay at a Holiday Inn express last night - but here's what I did...
I purchased a manifold that allows me to connect two senders and an oil pressure hose all together....one of the senders was for the AFS 3400 EM, the other sender is for the B&C dual-throw switch unit that allows for my Oil pressure idiot light and my hobbs meter (through a relay that starts my engine timer and the hobbs at the same time). I've had my engine running so I know it works correctly.
Ralph
RV6A N822AR (at) N06 - getting refresher training next weekend - then first flight
Posted: Wed Dec 31, 2008 11:35 am Post subject: Hour Meter/Oil Pressure Wiring |
Ralph:
What type of manifold and where did you purchase it.....Area you talking
about the Manifold, I think it's the VA-168 that Van's sells? I already
have this installed on my firewall.....
Posted: Wed Dec 31, 2008 12:02 pm Post subject: Hour Meter/Oil Pressure Wiring |
That sounds like the item...has three stubs on it, each with holes drilled on three sides.
I had to put a spacer between the firewall and the manifold in order for all of the senders to fit.
I have some pictures I'll send you......
