Guy Buchanan
Posted: Wed Dec 31, 2008 10:11 pm Post subject: [!! SPAM] Re: carb vents |
At 04:31 PM 12/31/2008, you wrote:
| Quote: | I was just looking at the vent lines on each side of my 582 carbs.
Both carbs are 'T' into a common line which goes out and down from
the engine compartment. I assume this was done to prevent any fires
in case of overflow. HOWEVER...I remember reading in a earlier
thread that it is not a good idea since now both carbs will have
equal air pressure and could screw up carb tuning...Thoughts ????? thanks
I've never heard an admonition for the 582. Certainly the
912 guys have some interesting stories to tell and modification of
their vent lines is discouraged. I suspect it depends on the
installation. Certainly you are potentially messing with the mixture,
as the Bing 54 relies on venturi / float differential for flow rate.
Were you to put that vent near a high velocity air stream, you could
get really lean. However, were you to use large diameter tube and
locate the end inside the cowl, away from moving air, I can't imagine
you'd hurt anything. You'd definitely want to A/B test it, though.
Guy Buchanan
San Diego, CA
K-IV/1200 w/ 582 C-box & Warp 3 blade
100% and flying thanks mostly to Bob Ducar
Deceased K-IV 1200
A glider pilot too. |
