n7cr(at)bellsouth.net Guest
Posted: Fri Mar 24, 2006 8:12 pm Post subject: CH-701 wing bottom trailing edge skin trimming at wingtip |
Question regarding trimming -
The 7V7-4 drawing shows the TE skin outboard edge trimmed back 35mm at the rear
channel at an angle, while the 7V9 rear skins wing tip trimming table has the
aft edge of the bottom skin 370mm from the centerline of rib #6.
7V7-4 has the distance of the edge from the centerline of rib #6 as:
1620 (length of TE skin)
- 1200 (distance to inboard side of rib #6
-10 (centerline of rib #6)
-35
= 375 mm.
That's a 5mm difference, which is what I'm measuring.
The question is, do I continue the straight line on 757-3 detailed on the table
on page 7V9 all the way to the trailing edge, or do I maintain the total TE skin
aft measurement (1620mm) and trim back the fwd edge of the TE skin by 40mm?
Rory
CH-701SP kit
Lacombe, LA
