dean.psiropoulos(at)veriz Guest
Posted: Sat Jan 03, 2009 6:50 pm Post subject: RV-List_Lousy Idle |
Thanks all for your inputs:
I'll be exploring every avenue that has been mentioned just to be sure
(cheap things first then on to more expense). The intake leak seems to be a
big "seller" and I'm getting a bit of feedback on wood propellers causing
idle problems on the big four cyl Lycomings, especially with fuel injection
installed. Wish I'd known this sooner and I would have opted for the
Sensenich fixed pitch but it's nice to have all you folks out there with
your collective knowledge to get me going in the right direction. If anyone
else has some more thoughts please forward them to me so I can check all
possibilities.
If everything checks out ok and there are no engine related culprits, I've
decided I'll take the plunge and order a Sensenich prop. Problem is that it
takes several weeks to get one and I don't really want to wait. So...does
anyone already have a Sensenich prop and spacer laying around that they
won't be using for a few months(for 180 HP Lyc 0-360)? If so maybe I could
purchase it from you and have the one I order shipped to you when it's
ready. Just thinking ahead. Also, if I go ahead with the metal prop, I'll
be selling my 70x82 Sterba wood prop (carved in 2006), spacer, crush plate,
Landoll inertia ring and fitted spinner (painted silver) so if anyone wants
a wood prop for 0-360 Lyc let me know and we'll work out a price for all or
part of the assembly. Thanks.
Dean Psiropoulos
ronlee(at)pcisys.net Guest
Posted: Sat Jan 03, 2009 7:21 pm Post subject: RV-List_Lousy Idle |
Why are you changing props for what is most likely a problem
in the engine? I have a wood prop on an O-360 and no problems
like you are having. I would find a competent mechanic to help
first.
Ron Lee
Posted: Sat Jan 03, 2009 8:08 pm Post subject: RV-List_Lousy Idle |
Dean,
I don't see how a wood prop could cause idle problems unless you have the
speed set too low. What is the idle speed of your engine? If it is below
700 RPM, it might be a factor.
KB
HCRV6(at)comcast.net Guest
Posted: Sun Jan 04, 2009 5:47 pm Post subject: RV-List_Lousy Idle |
I have a 13 pound composite prop (wood overlayed with glass) on my O-360 and it idles just fine. I seriously doubt that your idle problem is prop related. Why add 30 or 40 pounds or more to your airplane if not necessary?
Harry Crosby
RV-6 N16CX, 535 hours
mrobert569(at)hotmail.com Guest
Posted: Sun Jan 04, 2009 7:39 pm Post subject: RV-List_Lousy Idle |
Dean C
I don't think it is the prop.
I am going to be in Orlando next week. I don't have your number anymore. Give me a call at (509) 998-1793.
Mike Robertson
[quote] Date: Sat C 3 Jan 2009 21:49:17 -0500
Subject: RV-List_Lousy Idle
To: rv-list(at)matronics.com
--> RV-List message posted by: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net>
idle problems on the big four cyl Lycomings C especially with fuel injection
possibilities.
If everything checks out ok and there are no engine related culprits C I've
ready. Just thinking ahead. Also C if I go ahead with the metal prop C I'll
be selling my 70x82 Sterba wood prop (carved in 2006) C spacer C crush plate C
a
Life on your PC is safer C easier C and more enjoyable with Windows Vist='_new'>See how
