patreilly43(at)hotmail.co Guest
Posted: Mon Jan 05, 2009 4:01 pm Post subject: 582 Exhaust wrap |
Kitfoxers, I know I have seen the pros and cons of wrapping the exhaust with fiber glass exhaust insulating tape to reduce engine compartment temps. But, I wanted to hear from someone with personal experience pro or con that wrapped an exhaust on a 582. I have wrapped the down pipe and am considering blanketing the muffler also. I have used the fiber glass tape wrap on a street rod with good result.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
gary.algate(at)sandvik.co Guest
Posted: Mon Jan 05, 2009 4:15 pm Post subject: 582 Exhaust wrap |
One thing you should consider is that the exhaust system on a two stroke engine also serves as a conductor to radiate heat away from the engine block. Sometimes restricting the heat can lead to additional problems.
I have seen a large number of 582 installations in Kitfox aircrafts (including my last plane) and the engine compartment heat generated by the exhaust was never a real problem
Gary
Gary Algate
Classic 4 Jab 2200
Office Phone: +61 8 8276 7655
This e-mail is confidential and it is intended only for the addressees. Any review, dissemination, distribution, or copying of this message by persons or entities other than the intended recipient is prohibited. If you have received this e-mail in error, kindly notify us immediately by telephone or e-mail and delete the message from your system. The sender does not accept liability for any errors or omissions in the contents of this message which may arise as a result of the e-mail transmission.
“This year, instead of sending you a Christmas card in the mail, we have made a contribution to [url=Arial]UNICEF Australia[/url]. We wish you a safe and happy Christmas".
"Pat Reilly" <patreilly43(at)hotmail.com>
Sent by: owner-kitfox-list-server(at)matronics.com
06/01/2009 10:39 AM
Please respond to
kitfox-list(at)matronics.com To
<kitfox-list(at)matronics.com> cc
Subject
582 Exhaust wrap
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
Posted: Mon Jan 05, 2009 4:35 pm Post subject: 582 Exhaust wrap |
Gary C OK thanks for info. My heater hoses run within a couple inches of the down pipe and muffler. I hope there is enough space between them and the muffler.
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
Subject: Re: 582 Exhaust wrap
Date: Tue C 6 Jan 2009 09:44:16 +0930
Gary
Gary Algate
Classic 4 Jab 2200
This e-mail is confidential and it is intended only for the addressees. Any review C dissemination C distribution C or copying of this message by persons or entities other than the intended recipient is prohibited. If you have received this e-mail in error C kindly notify us immediately by telephone or e-mail and delete the message from your system. The sender does not accept liability for any errors or omissions in the contents of this message which may arise as a result of the e-mail transmission.
“This year C instead of sending you a Christmas card in the mail C we have made a contribution to UNICEF Australia. We wish you a safe and happy Christmas".
"Pat Reilly" <patreilly43(at)hotmail.com> Sent by: owner-kitfox-list-server(at)matronics.com
06/01/2009 10:39 AM
Please respond to
To
Subject
582 Exhaust wrap
Kitfoxers C I know I have seen the pros and cons of wrapping the exhaust with fiber glass exhaust insulating tape to reduce engine compartment temps. But C I wanted to hear from someone with personal experience pro or con that wrapped an exhaust on a 582. I have wrapped the down pipe and am considering blanketing the muffler also. I have used the fiber glass tape wrap on a street rod with good result.
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
[b]http://www.matronics.com/Navigator?Kitfox-Listhttp://forums.matronics.comhttp://www.matronics.com/contribution
[/b]
Quote: | http://www.matronics.com/Navigator?Kitfox-List
ronics.com
Roger Lee
Posted: Mon Jan 05, 2009 4:41 pm Post subject: Re: 582 Exhaust wrap |
Hi Pat,
I have a Flight Design CTSW. I have a 912ULS. I have a wrapped exhaust and so do quite a few other CT owners and it is fleet approved. My exhaust have been wrapped for 250 hrs. I wrapped my exhaust from the exhaust port down to the top of the muffler. It covers the knuckle just above the muffler. This helps keep any blow-by exhaust from blowing where I don't want it if it leaks and it keeps the radiated heat off any wires or hoses. It cuts down on the internal cowling temps to all the parts and when I pull the cowling off after a flight I can put my hand on the exhaust and not get burned. Proper tension on the exhaust springs is a must and really helps here. Our exhaust system is stainless steel and carbonization from higher temps is not the same problem as it is with just plain steel exhaust pipes. One thing to remember is not to over do the wrap. You only over lap the edges by about 3/8"-1/2" with the 2" wide wrap.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
Posted: Mon Jan 05, 2009 4:49 pm Post subject: 582 Exhaust wrap |
Pat
There would be no problem in wrapping that particular area of the pipe if you have a concern but I would keep it to the minimum. You can also consider a heat shield (piece of stainless steel) spaced about 1/2" away from the exhaust and as long as there is some air flow between the shield and the pipe you will be amazed at how this reduces heat radiation.
Hope this helps
Gary
Gary Algate
Classic 4 jab2200
patrick reilly <patreilly43(at)hotmail.com>
06/01/2009 11:12 AM
Please respond to
kitfox matronics <kitfox-list(at)matronics.com> cc
Subject
RE: 582 Exhaust wrap
Gary, OK thanks for info. My heater hoses run within a couple inches of the down pipe and muffler. I hope there is enough space between them and the muffler.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
Date: Tue, 6 Jan 2009 09:44:16 +0930
Gary
Gary Algate
Classic 4 Jab 2200
06/01/2009 10:39 AM
Please respond to
Subject
582 Exhaust wrap
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
http://www.matronics.com/Navigator?Kitfox-Listhttp://forums.matronics.comhttp://www.matronics.com/contribution >http://www.matronics.com/Navigator?Kitfox-List ronics.com ww.matronics.com/contribution
Posted: Mon Jan 05, 2009 4:53 pm Post subject: 582 Exhaust wrap |
Roger
I agree with your post and wasn't suggesting wrap couldn't be used - it's just that wrapping the entire muffler and pipe will retain a lot of latent heat in the engine -
Gary
Gary Algate
Classic 4 Jab2200a
"Roger Lee" <ssadiver1(at)yahoo.com>
06/01/2009 11:19 AM
Please respond to
kitfox-list(at)matronics.com cc
Subject
--> Kitfox-List message posted by: "Roger Lee" <ssadiver1(at)yahoo.com>
Hi Pat,
Roger Lee
Tucson, Az.
Rotax Service Center
520-574-1080
http://forums.matronics.com/viewtopic.php?p=223056#223056
Michael Logan
Posted: Mon Jan 05, 2009 4:54 pm Post subject: 582 Exhaust wrap |
My wife wrapped the exhaust on her 912 Pulsar and a crack developed underneath which we were not able to detect until too late. She is lucky to be alive.
Mike Logan
Series 5
956ML
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Pat Reilly
Sent: Monday, January 05, 2009 6:59 PM
Subject: 582 Exhaust wrap
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
_________________ Mike Logan
Fredericksburg, VA |
Paul A. Franz, P.E.
Posted: Mon Jan 05, 2009 6:38 pm Post subject: 582 Exhaust wrap |
On Mon, January 5, 2009 4:34 pm, patrick reilly wrote:
and muffler. I hope there is enough space between them and the muffler.Pat ReillyMod 3
A reflector shield that has air blowing across it is very effective since radiative
heat transfer is proportional to the 4th power of delta T. The temperature of the
shield will be far lower than the exhaust and hence the heat transfer to the surface
of the heater hoses will be significantly reduced.
I'd have some worries about pin hole exhaust leaks forming into the fiberglass wrap
that would convey some oil residue present in two stroke exhaust and eventually
becoming a fire hazard.
So, my feeling is fabricate some aluminum shields that are attached to the exhaust
with SS clamps where protection is desired.
Paul A. Franz
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
425.241.1618 Cell
_________________ Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office |
Posted: Mon Jan 05, 2009 8:32 pm Post subject: 582 Exhaust wrap |
Paul C Not too sure what the 4th power of delta T is C but I got the idea. Thanks for the info. I think SS shields would be better idea than wrap.
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
[quote] Date: Mon C 5 Jan 2009 18:36:50 -0800
Subject: Kitfox-List: RE: 582 Exhaust wrap
--> Kitfox-List message posted by: "Paul Franz - Merlin GT" <paul(at)eucleides.com>
So C my feeling is fabricate some aluminum shields that are attached to the exhaust
Paul A. Franz
Belle==
Paul A. Franz, P.E.
Posted: Mon Jan 05, 2009 9:29 pm Post subject: 582 Exhaust wrap |
On Mon, January 5, 2009 8:31 pm, patrick reilly wrote:
Quote: |
Paul, Not too sure what the 4th power of delta T is, but I got the idea. Thanks for
Delta T means temperature difference. Here it would mean the temperature difference
between the exhaust and the heater hoses. The 4th power would mean that temperature
difference raised to the 4th power. In other words if the absolute temperature
difference is double, then the amount of heat transferred is 16 times as much. It's
much worse than that though. Lets say the temperature of the exhaust pipe is 1100 °F
and the water hose surface is 250 °F without a shield and with a shield the outer
temperature of the shield is 400 °F then the heat transfer reduction is the ratio of
the absolute temperature differences raised to the 4th power:
((1100 - 250 + 459) / (400 - 250 + 459)) ** 4 = 21.3 times as much heat transfer to
the hoses without the shield as with the shield. (The 459 converts °F to °R - Rankine,
absolute temperature)
Note this simplified model doesn't take into consideration geometry effects but they
would only make this difference even larger since radiation from a cylinder is
inversely proportional to the square of the radius. I picked numbers to for
illustration purposes, and probably with a shield the surface of the water hoses would
be even less than 250 °F.
I think I would use shields made of some soft and malleable aluminum alloy clamping
them with SS hose clamps, keeping the space between the shield and the exhaust pipe
sufficient to get good airflow. The aluminum would weigh less and if you use big radii
on the bends and cuts this will resist cracking better than using SS. I would use
3/32" sheet in 6 in sections bent to wrap at about 3/4" greater radius than the
exhaust pipe with three bent down 3/4" U-shaped tabs on each end to clamp the shield
to the pipe where the shield goes around at least 180° of the exhaust pipe.
Paul A. Franz, P.E.
PAF Consulting Engineers
Office 425.440.9505
Cell 425.241.1618
Bellevue WA
425.241.1618 Cell
Float Flyr
Posted: Tue Jan 06, 2009 12:02 pm Post subject: 582 Exhaust wrap |
Wrap looks way cool on some motorcycles where it should stay. Wrapping increases the temperature inside the exhaust system. No way to get around that. Increased heat inside the wrap equals decreased life inside the wrap. Heat shields allow you to do periodic inspections of your exhaust without having to remove/replace the wrap and they do not increase the temperature of the exhaust itself.
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of patrick reilly
Sent: Tuesday, January 06, 2009 1:01 AM
To: kitfox matronics
Subject: RE: RE: 582 Exhaust wrap
Paul, Not too sure what the 4th power of delta T is, but I got the idea. Thanks for the info. I think SS shields would be better idea than wrap.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
> Date: Mon, 5 Jan 2009 18:36:50 -0800
> Subject: RE: 582 Exhaust wrap
> From: paul(at)eucleides.com
> To: kitfox-list(at)matronics.com
> Paul A. Franz
> Belle==
> Quote: | http://www.matronics.com/Navigator?Kitfox-List | 0123456789
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
