Additional L angles in fuselage.
Harvey Richards
PostPosted: Sat Jan 03, 2009 12:30 pm    Post subject: Additional L angles in fuselage. Reply with quote
I have seen where people have done the additional diagonal L bracing to cut down on oil canning. I am at that stage and have been wondering what to do. Some have gone with diagonals and some with complete X's between the Ls shown on the plans. Would not going straight across,parallel to the Ls, shown on the plans do the job. One could then tie them together with .025 gussets as already shown on the plans. This would take less L angles, be lighter and cut the unsupported distance in half also. Any thoughts? Thanks
CH 701
ch701builder(at)yahoo.com
PostPosted: Sat Jan 03, 2009 12:54 pm    Post subject: Additional L angles in fuselage. Reply with quote
That should work!! I put diagonals on my sides and plan on doing the parallel method on my top and bottom, (sections right behind the baggage compartment)
Keith
CH701 -- scratch
N 38.9940
W 105.1305
Alt. 9,100'
From: Harvey Richards <lisa.richards(at)ns.sympatico.ca>
Sent: Saturday, January 3, 2009 1:30:54 PM
Subject: Additional L angles in fuselage.
--> Zenith701801-List message posted by: "Harvey Richards" <lisa.richards(at)ns.sympatico.ca (lisa.richards(at)ns.sympatico.ca)>
I have seen where people have done the diagonal additional L bracing to cut down on oil canning. I am at that stage and have been wondering what to do. Some have gone with diagonals and some with complete X's between the Ls shown on the plans. Would not going straight across,parallel to the Ls, shown on the plans do the job. One could then tie them together with .025 gussets as already shown on the plans. This would take less L angles, be lighter and cut the unsupported distance in half also. Any thoughts? Thanks
CH 701
Harvey Richards
PostPosted: Sat Jan 03, 2009 12:58 pm    Post subject: Re: Additional L angles in fuselage. Reply with quote
Thanks Keith. Slight crimps with the fluting pliers to tighten the top edge of the L are also supposed to cut down on noise.
CH 701
larry(at)macsmachine.com
PostPosted: Sat Jan 03, 2009 1:15 pm    Post subject: Additional L angles in fuselage. Reply with quote
Keith and Harvey,
Diagonals are strongly recommended and I've also seen strips of duct
tape used as an effective means of knocking down the noise as well.
Keith
CH701 -- scratch
N 38.9940
W 105.1305
Alt. 9,100'
*From:* Harvey Richards <lisa.richards(at)ns.sympatico.ca>
*To:* zenith701801-list(at)matronics.com
*Sent:* Saturday, January 3, 2009 1:30:54 PM
*Subject:* Additional L angles in fuselage.
<lisa.richards(at)ns.sympatico.ca <mailto:lisa.richards(at)ns.sympatico.ca>>
CH 701
kmccune
PostPosted: Sat Jan 03, 2009 1:29 pm    Post subject: Re: Additional L angles in fuselage. Reply with quote
Maybe I'm blind, as others have told me this, but I can not find any oil canning bracing in the plans. So I was planning on x bracing. What page is this one?
Kevin
“Always do what you are afraid to do.�
R.W. Emerson (1803-1882)
Dorothy McCune
Harvey Richards
PostPosted: Sat Jan 03, 2009 1:36 pm    Post subject: Re: Additional L angles in fuselage. Reply with quote
Thanks also Larry. I can see the advantage of diagonal L angles for bracing strength but believed,maybe mistakenly, that the L angles were only to provide stiffness to the unsupported sheet metal. I was looking for a reason why the diagonal was better as there may be something I'm missing.
CH 701
Harvey Richards
PostPosted: Sat Jan 03, 2009 1:37 pm    Post subject: Re: Additional L angles in fuselage. Reply with quote
There is none shown on the plans Kevin thats why I'm unsure
CH 701
bobkat
PostPosted: Sat Jan 03, 2009 1:44 pm    Post subject: Additional L angles in fuselage. Reply with quote
I put X's in them, though maybe a single diagonal would be enough. Even
slipping as much as possible I've had no oil canning at all, except the
bottom hatch which was cured by putting in an X brace.
I'm not sure how everyone else does it, though when I looked for photos on
the internet most that I saw seemed to have X braces.
PostPosted: Sat Jan 03, 2009 6:11 pm    Post subject: Additional L angles in fuselage. Reply with quote
Harvey,
The angles provide a best way to reduce the large unsupported area and
help add to the structural integrity of the fuselage. Beyond that, the
addition of
duct tape strips broadly spaced will dampen the sound a lot. The first
three bays behind the seats are the worst and the rearmost is probably a
hard one to
get angle into, but worth it.
Larry
CH 701
raymondj(at)frontiernet.n
PostPosted: Sat Jan 03, 2009 6:21 pm    Post subject: Additional L angles in fuselage. Reply with quote
I don't recall seeing any discussion of the possibility of putting X creases
in the panels to increase stiffness. Am I missing something?
Raymond Julian
Kettle River, MN
"Hope for the best,
but prepare for the worst."
Harvey Richards
PostPosted: Sun Jan 04, 2009 12:17 pm    Post subject: Re: Additional L angles in fuselage. Reply with quote
Have decided to follow the norm and go with the X bracing . I can see the advantage to tying the top and bottom longerons together on the diagonal and the four smaller triangles between the Ls should be stronger.
CH 701
Curt.Thompson(at)verizon.
PostPosted: Tue Jan 06, 2009 2:15 pm    Post subject: Additional L angles in fuselage. Reply with quote
I'm going against the norm and do mine with single diagonal braces of a
square truss like is shown in the following link:
http://www.supplierlist.com/photo_images/32654/Truss.jpg
I'm going to use .016" AL with about 50mm rivet spacing. I will try to tie
them into the corners.
Curt
Plans building CH701
john.marzulli(at)gmail.co
PostPosted: Tue Jan 06, 2009 2:46 pm    Post subject: Additional L angles in fuselage. Reply with quote
Kinda like what I have done?
http://3.bp.blogspot.com/_mhDbWUJRTOE/RxW3sp5NmnI/AAAAAAAAC_g/F6K9oqBnoAQ/s1600-h/IMG_3413.jpg
Here you can see one of the spots where I installed some sound deadening material: http://3.bp.blogspot.com/_mhDbWUJRTOE/RxsWJJ5NmrI/AAAAAAAADAU/rXSuCYd_TtY/s1600-h/IMG_3425.jpg
John Marzulli
http://www.GenevieveMarzulli.org/
http://marzulli.smugmug.com/
http://701Builder.blogspot.com/
http://www.JohnMarzulli.net/
On Tue, Jan 6, 2009 at 2:14 PM, Curt Thompson <Curt.Thompson(at)verizon.net (Curt.Thompson(at)verizon.net)> wrote:
[quote] --> Zenith701801-List message posted by: "Curt Thompson" <Curt.Thompson(at)verizon.net (Curt.Thompson(at)verizon.net)>
Curt
dougsnash
PostPosted: Tue Jan 06, 2009 4:19 pm    Post subject: Additional L angles in fuselage. Reply with quote
Curt, this is basically what I have done but am a little concerned about the oil cannieness just aft of the baggage area that this has left me with.
The rest of the bays aft of the largest one seem nice and tight with only the one diagnal stiffener in each.
Take this all with a grain of salt though as I am not finished building yet.
Doug MacDonald
CH-701 Scratch Builder
NW Ontario, Canada
--- On Tue, 1/6/09, Curt Thompson <Curt.Thompson(at)verizon.net> wrote:
Subject: RE: Re: Additional L angles in fuselage.
Date: Tuesday, January 6, 2009, 4:14 PM
Thompson" <Curt.Thompson(at)verizon.net>
Curt
PostPosted: Tue Jan 06, 2009 5:13 pm    Post subject: Additional L angles in fuselage. Reply with quote
All,
I seem to remember that Les Goldner used wood molding, glued to the inside running horizontal. He does monitor the list (when he isn't out flying) maybe he can join in and tell about his experience!!
Are you there Les?
Keith
CH701-scratch
Sent: Tuesday, January 6, 2009 5:18:37 PM
--> Zenith701801-List message posted by: MacDonald Doug <dougsnash(at)yahoo.com (dougsnash(at)yahoo.com)>
Doug MacDonald
NW Ontario, Canada
--- On Tue, 1/6/09, Curt Thompson <Curt.Thompson(at)verizon.net (Curt.Thompson(at)verizon.net)> wrote:
[quote] From: Curt Thompson <Curt.Thompson(at)verizon.net (Curt.Thompson(at)verizon.net)>
To: zenith701801-list(at)matronics.com (zenith701801-list(at)matronics.com)
Curt
PostPosted: Tue Jan 06, 2009 8:24 pm    Post subject: Additional L angles in fuselage. Reply with quote
John,
I’m going to do the top and bottom too. I’m going to arrange them like the square truss picture I linked to earlier.
Curt
From: owner-zenith701801-list-server(at)matronics.com [mailto:owner-zenith701801-list-server(at)matronics.com] On Behalf Of John Marzulli
Sent: Tuesday, January 06, 2009 2:46 PM
Subject: Re: Zenith701801-List: Re: Additional L angles in fuselage.
John Marzulli
[quote] [b]
JohnDRead(at)aol.com
PostPosted: Tue Jan 06, 2009 8:35 pm    Post subject: Additional L angles in fuselage. Reply with quote
Hi Curt;
 I made diagonal braces from standard "L" as they are on the factory 701. The rearmost diagonal was my starting point, it goes from bottom skin at the rear to upper skin toward the front. The next brace started at the top skin and so on. I tied them into the corners near the vertical "L", I used A4 rivets at the standard rivet spacing of 40 mm. If you look on the Zenith web site they are visible. I have flown the factory 701 and did not hear any oil canning.
John Read
CH701 - Elbert CO - Jabiru 3300
Phone: 303-648-3261
Fax: 303-648-3262
Cell: 719-494-4567
Stay up-to-da news - from fashion trends to celebrity break-ups and everything in between.
PostPosted: Wed Jan 07, 2009 8:32 am    Post subject: Additional L angles in fuselage. Reply with quote
Thanks for the feedback John.
The diagonals are going in different directions on the factory CH701 than they are in the CH750. At least that is what I observed at Oshkosh. I didn’t ask why.
Curt
From: owner-zenith701801-list-server(at)matronics.com [mailto:owner-zenith701801-list-server(at)matronics.com] On Behalf Of JohnDRead(at)aol.com
Sent: Tuesday, January 06, 2009 8:35 PM
Subject: Re: Additional L angles in fuselage.
Hi Curt;
John Read
Phone: 303-648-3261
Fax: 303-648-3262
Cell: 719-494-4567
[quote] [b]
lgold(at)quantum-associat
PostPosted: Thu Jan 08, 2009 12:32 pm    Post subject: Additional L angles in fuselage. Reply with quote
Harvey,
My 7-01 has been flying for over a year. Rather than put in additional "L"s,
I glued in some cheap light 1" wood "L" moldings and painted over them in
places in the fus where I wanted to stop the oil canning. This method seems
to be working very well. The oil canning has been reduced and this is a
lighter and a much simpler approach than having to rivet in metal "L"s.
Les
dlorrzen701(at)earthlink.
PostPosted: Thu Jan 08, 2009 7:26 pm    Post subject: Additional L angles in fuselage. Reply with quote
Les, what brand of glue did you use?
David L. Orr
