Posted: Thu Jan 15, 2009 9:38 am Post subject: Landing gear |
Jim Hauck- Last May you suggested using steel tubing for the landing legs on a Firefly or old Firestar with the 1" legs. Your suggestion was to go half way down with the 1", and change to 3/4". I am considering steel legs, and wondered about the half way comment. Halfway from the bottom of the "A" frame? I know about using 4130 and hardening to R48. Do you pre-drill before hardening? I haven't ordered any legs yet, but If I go to the new 1 1/8" Firefly legs I will have to drill out the aluminum tube spacer in there.
Also, when joining the 1" to the 3/4" do you just run the bolt through the "A" frame at the usual spot, or another bolt lower, or a weld at the top and allow the lower joint to move?
Bill Sullivan
Windsor Locks, Ct.
5 degrees and overcast, light snow flurries
Posted: Thu Jan 15, 2009 10:41 am Post subject: Landing gear |
Bill C
I'm not Jim C but I can answer your question regarding drilling into the 4130 hardened to R-48.
I just drilled into my gear legs a few weeks ago C to secure my axles. I failed to drill them before I
sent them off to be Rockwell hardened. Big mistake!! Those suckers are hard as a bleaping rock!!
They were so hard C I couldn't get a punch to make a centering hole dent. Suffice to say C if you want
to do any machining on them C do it PRIOR to hardening. Drilling them afterwards is 20 times as difficult!
Mike Welch
MkIII
+1 degree this morning C too cold to work on my plane in the shop.
Date: Thu C 15 Jan 2009 09:37:37 -0800
Subject: Landing gear
Jim Hauck- Last May you suggested using steel tubing for the landing legs on a Firefly or old Firestar with the 1" legs. Your suggestion was to go half way down with the 1" C and change to 3/4". I am considering steel legs C and wondered about the half way comment. Halfway from the bottom of the "A" frame? I know about using 4130 and hardening to R48. Do you pre-drill before hardening? I haven't ordered any legs yet C but If I go to the new 1 1/8" Firefly legs I will have to drill out the aluminum tube spacer in there.
Also C when joining the 1" to the 3/4" do you just run the bolt through the "A" frame at the usual spot C or another bolt lower C or a weld at the top and allow the lower joint to move?
Bill Sullivan
Windsor Locks C Ct.
5 degrees and overcast C light snow flurries
| Windows Live™ Hotmail®: Chat. Store. Share. Do more with mail. Check it out. [quote][b]
jimh474(at)embarqmail.com Guest
Posted: Thu Jan 15, 2009 11:19 am Post subject: Landing gear |
Bill;
Do all drilling and welding prior to having them heat treated.
You want the gear legs to run all the way up in the gear socket till they bottom out at the "V" junction of the gear sockets.
On my brothers Fire Star which we made steel gear legs for way back in the late 80's we used 36 " gear legs. This give you more ability to rotate on take off.
On the Fire Star, I would use one size tubing for the entire length as it is much heavier than the Fire Fly.
Use 1 1/8" .120 wall tubing for your gear legs and for the axle sockets use 7/8 .120 wall tubing. This will fit the 5/8 axle.
I would weld tubing for the axle insert at + 7 degrees camber. This will put your wheels about 2 degrees positive when you are in the airplane.
When you heat treat the chromemoly tubing it then becomes a spring.
If I can help you with anything else feel free to ask.
Jim Hauck
aslsa.rng(at)gmail.com Guest
Posted: Thu Jan 15, 2009 11:42 am Post subject: Landing gear |
Jim, If you don't mind a welding question, did you use any special gas when mig welding the Kolb frames or did you just use steel mix.
Rick
On Thu, Jan 15, 2009 at 1:17 PM, Jim Hauck <jimh474(at)embarqmail.com (jimh474(at)embarqmail.com)> wrote:
| Quote: | Bill;
Jim Hauck
[/b] |
Posted: Thu Jan 15, 2009 12:12 pm Post subject: Landing gear |
Rick;
Most of the welding I do on Kolb's, it TIG, when I use MIG I use 25% Argon and 75% CO2. This keeps the splatter down considerably.
Jim H
Posted: Thu Jan 15, 2009 3:18 pm Post subject: Landing gear |
Thanks for the prompt responses. Jim- I may downsize a bit from your recommendations, as this particular plane is probably lighter than the current Firefly. John thinks it is a very early one, built to Part 103 specs. I'll check weights,as I want to add brakes this time.
If you have to drill a spring, spot anneal first. Drill with lots of coolant, as heat will harden the material as you drill. I have ended up with some weird looking drill bits finding this out. Sometimes you don't know what the steel is, and it can be interesting trying to drill it.
Bill Sullivan
Windsor Locks, Ct
Posted: Thu Jan 15, 2009 3:53 pm Post subject: Landing gear |
Bill:
The specs Jim gave you are the specs that work.
We didn't come up with them the first time around. We tried 1"X.090" heat treated to 42 RC. These were our first steel legs. I didn't know where to start with heat treating. Got the 42 RC from Max Air and went with it. It was too soft. 48 RC is hard enough, but not too hard. They will bend 90 deg before they break. I have tested them in actual situations.
If you go lighter, the system will fail eventually.
Bill Sullivan
Windsor Locks, Ct.
_________________ John Hauck
Titus, Alabama |
Posted: Thu Jan 15, 2009 4:26 pm Post subject: Landing gear |
John- Do you think that spec might be a little too ridgid for a 103 plane? Gross weight will be about 475 total. Jim's original letter of May 19, 2008 gave me the lighter spec legs.
Bill Sullivan
Windsor Locks, Ct.
8 degrees, and going to -1 tonight
Posted: Thu Jan 15, 2009 4:42 pm Post subject: Landing gear |
Bill:
Those are the legs I flew very successfully with on my 1986 original Firestar.
Once heat treated, the legs are springs.
Bill Sullivan
Windsor Locks, Ct.
Titus, Alabama |
Posted: Thu Jan 15, 2009 4:48 pm Post subject: Landing gear |
I'll drill the sockets for the 1 1/8", if the weather ever gets warmer. Thanks.
Bill Sullivan
Windsor Locks, Ct.
Posted: Thu Jan 15, 2009 4:58 pm Post subject: Landing gear |
Bill:
My original FS came with 1" aluminum legs. I bent them taxiing before I even got in the air the first time.
Tried Twinstar legs, 1.125", and bent them too. Then we started working on some heat treated steel legs.
I had to remove the aluminum tube sleeve from the gear leg sockets. Made a simple home made slide hammer and went to work. Took a little effort but the sleeves lost the battle. I also had to clean up some places where the welds had burned through before I could get the legs all the way into the socket up to the intersection where they bottomed out.
We used gear leg/axle sockets initially. After a couple failures, we started welding the axle sockets to the bottom of the gear legs. That fixed that problem.
[quote] I'll drill the sockets for the 1 1/8", if the weather ever gets warmer. Thanks.
Bill Sullivan
Windsor Locks, Ct.
Titus, Alabama |
Posted: Fri Jan 16, 2009 4:14 am Post subject: Landing gear |
John and Jim- Thanks for the feedback. It was just that old message (I had saved it) that caused the confusion. I have 3 sets of the old 1" legs (all bent) that came with it- one set is 6061, bent while taxiing. I have the old type axle fitting, 3/4" socket and a 5/8" tube for an axle. I intend to re-fit with brakes, so changes have to be made.
While I'm digging in your memories of that old Firestar- What kind of empennage attachment was on it? Mine doesn't match any photos I have been able to find. The lower "skeg" end has two pieces of steel tubing going forward into the fuselage, and no exterior supporting ring. Old style?
2 below zero at 7am, and where is the global warming they have been promising?
Bill Sullivan
Windsor Locks, Ct.
Dana
Posted: Fri Jan 16, 2009 4:29 am Post subject: Landing gear |
At 07:13 AM 1/16/2009, william sullivan wrote:
| Quote: | While I'm digging in your memories of that old Firestar- What kind of
I don't know about the FS, new or old, but that's how the US is built.
| Quote: | 2 below zero at 7am, and where is the global warming they have been
promising?
Yeah, I have to leave the water dripping all night to keep the pipes from
freezing. But haven't you heard? It's not "global warming" any more, it's
"climate change". That way they can say they're right no matter what the
climate does. The scientists are all abandoning the global warming thing
like rats fleeing a sinking ship, leaving only the brain dead or corrupt
politicians on board
-Dana
Chaste: why virgins run.
Posted: Fri Jan 16, 2009 7:04 am Post subject: Landing gear |
Bill:
I think you are referring to the tail post attachment.
That is the way it was done on early Firestars. No exterior ring.
On my Ultrastar, the inboard rib attached to the main spar with two tubes inserted into the spar. This was a poor method of attachment because it allowed the wing to twist. Aileron input was counteracted by wing twist. One had to be very gentle with ailerons.
The Ultrastar was not the only aircraft with wing twist problems. One of my old Air Force buddies flew B-47's. That aircraft had the same problem as the Ultrastar.
mkIII - 17F at hauck's holler
Bill Sullivan
Windsor Locks, Ct.
Titus, Alabama |
Dana
Posted: Fri Jan 16, 2009 10:19 am Post subject: Landing gear |
At 10:04 AM 1/16/2009, John Hauck wrote:
On my Ultrastar, the inboard rib attached to the main spar with two tubes inserted into the spar. This was a poor method of attachment because it allowed the wing to twist. Aileron input was counteracted by wing twist. One had to be very gentle with ailerons. |
John, did you ever do the mod (I think it was Richard Swiderski who posted details on it) to add the collar on the wing root? It's tempting, but a bit of work, and I wonder how much improvement it would actually make.
-Dana
Be wary of strong drink. It can make you shoot at tax collectors-- and miss. [quote][b]
Posted: Fri Jan 16, 2009 10:35 am Post subject: Landing gear |
Dana:
No, we did not make that change. Would have been easier to build new wings with an updated inboard rib.
Also, the improvements of the original FS over most of the problems with the US out weighed any decision to put more time and money in the US.
The US had a lot of little problems and was easy to bend things.
The FS also had problems in some of the same areas. Winter of 1988 and 89, Jim and I completely overhauled and modified my FS. A lot of the initial problems were solved by Jim adding a couple additional tubes here and there.
[quote] John, did you ever do the mod (I think it was Richard Swiderski who posted details on it) to add the collar on the wing root? It's tempting, but a bit of work, and I wonder how much improvement it would actually make.
-Dana
Titus, Alabama |
Posted: Fri Jan 16, 2009 10:37 am Post subject: Landing gear |
Dana- Has yours been fixed?
Bill Sullivan
Windsor Locks, Ct.
herbgh(at)nctc.com Guest
Posted: Fri Jan 16, 2009 10:55 am Post subject: Landing gear |
John
Coming from you...those "here and there tubes" sound important...can you embellish?
Also Dana and John...I am planning to use a set of modified ultra star root ribs on my Firefly/Firestar /ultrastar Tri Fly hybrid... Is the US "h" section sort of root attachment to spar considered to be inferior...Looks plenty strong to me. Herb
At 12:35 PM 1/16/2009, you wrote:
[quote]Dana:
-Dana
Posted: Fri Jan 16, 2009 11:07 am Post subject: Landing gear |
Herb:
The original method of attaching inboard rib to main spar on the US was less than desireable. It allowed the wing to twist when ailerons were operated, effectively canceling out aileron input. That is why Homer came up with the collar for attaching main spar and also tail post. Light aileron loads worked pretty good, but if you had to get a little heavy handed, the more aileron applied the more the wing would twist. Scared hell out of me first time I got into that situation. I was used to flying helicopters. When I gave them cyclic input the helicopter responded immediately. Brand new to airplanes and especially the Ultrastar, I dove on my house, pulled up and tried to do a big wing over, but the more aileron I put in the more the wing twisted and I ended up effectively wings level. Had a lot to learn about these little airplanes.
[quote] Also Dana and John...I am planning to use a set of modified ultra star root ribs on my Firefly/Firestar /ultrastar Tri Fly hybrid... Is the US "h" section sort of root attachment to spar considered to be inferior...Looks plenty strong to me. Herb
Titus, Alabama |
Posted: Fri Jan 16, 2009 11:38 am Post subject: Landing gear |
Brings up 'nuther question...Did you have the braces on the drag spar? Also wondering if my 24 foot wing span will be as susceptible to the twist? Logically it would not..
Thanks Either way..I will make the collar...or hook a couple out of Travis! Herb
At 01:06 PM 1/16/2009, you wrote:
[quote]Herb:
[/b]
