Michel
Posted: Mon Jan 26, 2009 1:45 am Post subject: X-Plane test |
| Quote: | From: av8rps [paul676(at)tds.net]
I know nothing about X-plane, but what we are trying to find out here is how a Kitfox
IV will perform if the standard Ribblet 32 ft wing is cut down to a 26 ft span.
Hello Paul,
First, a word of warning: although this is an excellent simulator as it divides everything to a blade element with own coeficient of lift, drag and moment ... it is only a simulator with its limitations.
For example, to simulate the flaperons, I had to cheat. Why? Well, a flaperon stall much later than the wing because the air passing under the wing is pressed on the top of the flaperon, keeping it laminar.
If a simulator was to do exactly the same thing, the interaction between different surfaces should be calculated using Computerized Fluid Dynamic (CFD) that divides the entire volume of space into independant parcels. That can't be done in real time.
X-Plane takes into account simple things like the prop wash effect on the control surfaces. But not much more. So, to make my flaperons, I had to manually change the lift coefficient and stall angle that exceeds then 20 degrees AOA.
Anyway, I made a copy of my Kitfox model 3 with Jabiru 2200 and shortened the wings to 26 feet span. The result was interesting!
I can't really measure the take-off distance. To do that, I should mark the ground with lines and use replay to see when it lifted. What I did is:
Stall speed at idle: normal: 34 mph. Short wing: 39 mph
Max speed at WOT: normal: 110 mph. Short wing: 115 mph.
Climb rate at 60 mph: normal: 1,000 ft/m. Short wing: ... also 1,000 ft/m!
Please, take those figures not as absolute but relative values.
The general feeling is this: performances weren't very much affected but the feeling of flying was quite different! First, I was surprised to see how much roll power I had! More than with the long wings. (Yes, the flaperons were also shortened). On second thoughts, it may make sense: shorter flaperons but also shorter wings that present drag to roll motion.
The general feeling of flying was more flimsy with the short wings. For example, with the normal wings, a stall induces a soft mush-down; something I also experience in real life with my plane. But the short wing model stall harder. Uncoordinate stall went much faster in a wing drop and possible spin with the short wings. It felt better to fly the unmodified plane but perhaps that's because I am used to it.
I hope it helps.
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200 ... flying as PAX
_________________ Kitfox 3 - Jabiru 2200 |
Lynn Matteson
Posted: Mon Jan 26, 2009 12:11 pm Post subject: X-Plane test |
Hey Michel-
Why don't you try a "ski tuck" with a Speedster model IV, and see
what it feels like. : )
Lynn Matteson
Jabiru 2200, #2062, 600.2 hrs
Sensenich 62x46
New skis done and flying
On Jan 26, 2009, at 4:41 AM, Michel Verheughe wrote:
| Quote: | > From: av8rps [paul676(at)tds.net]
> a 26 ft span.
Hello Paul,
limitations.
laminar.
What I did is:
1,000 ft/m!
I am used to it.
I hope it helps.
Michel Verheughe
Norway
List">http://www.matronics.com/Navigator?Kitfox-List</a>
forums.matronics.com</a>
www.matronics.com/contribution</a>
</b></font></pre>
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
av8rps
Joined: 05 Jan 2008 Posts: 33 Location: Central Wisconsin
Posted: Mon Jan 26, 2009 8:35 pm Post subject: Re: X-Plane test |
Michel,
Thanks so much for doing this test on your X-plane software. The results were pretty much what I had expected based on what I had read, with the exception of the flimsy handling characteristics. I would have thought the higher wing loading would actually make it feel stabler. But as you said, it's not necessarily an exact science, so once again the real test is just that...
I do wonder how the newer airfoil used on the Model IV along with the wider symetrical-airfoiled flaperons might change the numbers, as there is a significant difference between a real Model 3 and a Model 4 for top speed. I learned that the first time I put the nose down on my Model IV with the long wing...it builds up speed fast. Much faster than does the older higher lift airfoil used on the Avids and the Kitfox 1-3 models, which feel like they hit a wall once you exceed 100 mph. At least that's been my experience.
I'm curious, does X-plane accurately simulate your jabiru powered Model 3 for performance specs? It sure sounds like it does a good job with handling and control feel. I'm pretty impressed that you could actually sense and feel the increased stall characteristics with the shorter wing. That's pretty cool!
Thanks again Michel.
Paul
| Michel wrote: | | Quote: | From: av8rps [paul676(at)tds.net]
Hello Paul,
I hope it helps.
Michel Verheughe
Norway
<pre> |
_________________ Model IV-1200 912ul Amphib
Avid Flyer Sn#1 and Sn#26
Highlander 912s taildragger
Lake Amphibian
Central Wisconsin
paul676@tds.net |
av8rps
Posted: Mon Jan 26, 2009 9:12 pm Post subject: Re: X-Plane test |
Michel,
One last thought; Would you consider doing a 28'8" wing like the Speedser has for comparisons against the 26 and 32 ft wings? I thought that might help us "balance" the data results better.
Paul
Lake Amphibian
Central Wisconsin
paul676@tds.net |
Michel
Posted: Thu Jan 29, 2009 11:18 am Post subject: X-Plane test |
Lynn, I tried to make skis with X-Plane and it looks good but as long as snow is not modelled in the simulator, it is only an eye-candy and of no other value.
My wrong wording, Paul. What I meant to say was: more agile. But because unusual for me, it felt more unpredictable.
| Quote: | I'm curious, does X-plane accurately simulate your jabiru powered Model 3 for
performance specs?
No, it doesn't. The simulator has plenty of parameters you can define yourself and I have been doing that for more than one year, flying my plane and modelling, until I was more or less pleased with the similarity.
I met Austin Meyer, the creator of X-Plane, at two occasions; once in Italy and once in Germany (he is American but comes sometimes here to meet with some of us). We have the same vision for the simulator: to make it an excellent experiemental tool (hence the X in the name). But to make a living he must sell. And the competitor is MS FS that has a lot of eye-candy. He then uses much time to create nice effects available via languages like OpenGL and aimed at video games.
The truth is that perhaps one third of the users are interested in the actual modelling, one third only fly airliners online, flying perfect SID and STAR with real-time ATC, and one third is just fooling around, flying a 747 inverted a few feet over the ground.
I have proposed to have, in addition to the PlaneMaker and AirfoilMaker tools something called PropulsionMaker that would take all the parameters from an engine and distribute standard engine models like it already exists for the NACA airfoils.
But it is not easy. For example if you use a propeller with e.g. Clark-Y airfoil, you get a perfect propeller based on NACA data. But in reality, no propeller is perfect. So, you must decrease slightly the lift of the elements making the propeller in order to meet the real-life performance.
With that in mind, I am not sure I should try to model the Speedster. I wouldn't like to see people making a wrong decision on what is, after all, done with the best intention but not accurate data.
Michel Verheughe
Norway
Lynn Matteson
Posted: Thu Jan 29, 2009 1:10 pm Post subject: X-Plane test |
Thanks for the attempt, Michel.
Lynn Matteson
Sensenich 62x46
On Jan 29, 2009, at 2:06 PM, Michel Verheughe wrote:
| Quote: | Lynn, I tried to make skis with X-Plane and it looks good but as
N369LM |
JetPilot
Posted: Thu Jan 29, 2009 1:32 pm Post subject: Re: X-Plane test |
X-Plane is a neat piece of software, but it is far from being accurate for these kinds of mods. It is fun and informative to play around with, but we need to see this piece of software for what it is, more of an enthusiast game than a tool made for serious aircraft design.
If aircraft design and mods could be determined by simply plugging in all the info into X-Plane, most planes would be built perfectly optimized for their purpose right from the start. The reality is, nothing we have ( Boeing Might Have ) right now that we can use on our Ordinary PC's ( Again Boeing, Airbus, etc. use supercomputers ) will tell us accurately the effect of mods and design changes on a Kitfox.
Mike
Kolb MK-III Xtra, 912-S |
propellerdesign(at)tele2. Guest
Posted: Thu Jan 29, 2009 11:43 pm Post subject: X-Plane test |
Fact is that not even Boeing or other is getting it right first time, more
then seldom test flight lead to changes.
Jan
Michel
Posted: Fri Jan 30, 2009 2:06 am Post subject: X-Plane test |
| Quote: | From: JetPilot [orcabonita(at)hotmail.com]
of mods.
I agree, Mike. I have learned much about aerodynamic by doing slight changes and see how it affects the performance and handling. But this is relative observation, not absolute.
I can see how, e.g. moving the CoG aft affects spin tendency. But I wouldn't build and fly a real plane by those data!
Michel Verheughe
Norway
JetPilot
Posted: Fri Jan 30, 2009 1:05 pm Post subject: Re: X-Plane test |
X Plane is a fun way to try those " Worst Case Scenarios " that you would not want to do in real life ! I like simulators, have used computer flight simulators since the first ones came out on the Commodore back in the early 80 's The only reason I bought computers in the early years before the Internet was for the flight sims
Maybe a better way of saying what I said in my earlier post is: If I were going to go to the work and expense of a physical modification to my airplane, I would base it on sound aerodynamic theory and research of similar modifications people had done rather than on a simulation result.
Mike
