Posted: Mon Jan 26, 2009 5:56 pm Post subject: Joining many wires to one - rocker switch lights to dimmer |
At 03:31 PM 1/26/2009, you wrote:
<MauleDriver(at)nc.rr.com>
Can anyone offer some advice on how to connect the leads for my 8 or
9 Honeywell rockers to a single periheliondesign dimmer?
The switches all have Fast-on terminals which I can easily connect to.
But I'm a bit stumped on the best way to have 8 or 9 separate leads
connected together and finally connected to a dimmer.
I've been through most/all of Bob's stuff but just can't find the
right approach.
Here's one of several solutions for bringing multiple
lighting leads and their ground into an orderly joining:
http://aeroelectric.com/Pictures/Wiring_Technique/minibus.jpg
http://aeroelectric.com/Pictures/Wiring_Technique/Minibus1.jpg
http://aeroelectric.com/Pictures/Wiring_Technique/Minibus2.jpg
Alternatively, it's perfectly valid to lap multiple strands
of wires and fixture them for soldering with a single strand
of fine copper. Make the solder joint and then cover with
heat shrink.
http://www.aeroelectric.com/articles/PM_Solder_Sleeve/PM_Solder_Sleeve.html
Finally, if the wires are small (22AWG or smaller) you can
consider sticking multiple strands of wire into each end of
a butt-splice. Note that a blue spice will easily accommodate
three 20AWG wires, I suspect you can get 5-6 in each end.
This allows you to bring 10-12 wires together in a common,
well connected junction.
http://www.aeroelectric.com/articles/multiplewires/multiplewires.html
http://aeroelectric.com/Pictures/Terminals/3x20Blue.jpg
http://aeroelectric.com/Pictures/Terminals/PIDG-Splices.jpg
( -Thomas Paine 1776- )
hammer408(at)comcast.net Guest
Posted: Tue Jan 27, 2009 3:24 pm Post subject: Joining many wires to one - rocker switch lights to dimmer |
Bob:
Looking at your mini-bus creation using d-sub, can you give me an idea how
many amps can I put thru those d-sub pins ( I guess is a better question is
what are each of the pins rated for)??...obviously, I looking at using18-22
awg wire..probably no higher than 5 amps, but maybe as high as 7.5 amps if
possible.
thanks
Henry
