Defrost fan steel mesh filter screens
hotwheels
PostPosted: Thu Jan 29, 2009 10:00 am    Post subject: Defrost fan steel mesh filter screens Reply with quote
I ran across these the other day. The mesh screen covers would be a bit more attractive than some other alternatives I've seen discussed in the past.
http://www.directron.com/smf80.html
Jay
pitts_pilot(at)bellsouth.
PostPosted: Thu Jan 29, 2009 11:24 am    Post subject: Defrost fan steel mesh filter screens Reply with quote
Those are neat looking. My solution is to get window screen (used to be
able to get aluminum, but now all I find is fiberglass) and spray a wet
coat of paint on it to match and protect the screen from UV.
Linn
Jay
http://forums.matronics.com/viewtopic.php?p 27521#227521
bcondrey
PostPosted: Thu Jan 29, 2009 11:41 am    Post subject: Defrost fan steel mesh filter screens Reply with quote
Regardless of which direction you go, it turns out that the location
where the fans are (at least in my install) aren't really that visible
in the first place. Now, if you had chrome grills or something like
that where they stood out it would certainly make a difference. I've
got the grill area painted flat black and the covering I used on the
glare shield is also flat black, fake leather. Unless you're looking
for the fans, you really don't notice that they're there.
Here's what I'm using for the glareshield cover and edging:
http://www.cleavelandtoolstore.com/prodinfo.asp?number=GSF15
I've also heard that Abby also now makes glare shield covers and will
put custom cutouts in for defrost fans.
Neal.George(at)hurlburt.a
PostPosted: Thu Jan 29, 2009 12:52 pm    Post subject: Defrost fan steel mesh filter screens Reply with quote
Lynn -
Check your local Ace Hardware.
The one here in Navarre, FL keeps a roll of brass screen on the shelf.
Not cheap, but it doesn't take much and it won't rust...
Neal
Linn
Tim Olson
PostPosted: Thu Jan 29, 2009 1:29 pm    Post subject: Defrost fan steel mesh filter screens Reply with quote
For the little bit of money, that's not bad. They'd look, good.
I didn't find screens like that at the time, so I did what Linn
talks about and cut aluminum screen and painted it black.
I did find that it was important to paint everything black up there.
Even the sticker from the fan, and any screws. The reflections
otherwise were as annoying as heck.
Also, it's definitely good to add screens EVEN IF you have a
wire grill, like I have. On mine, the wire grill protects
the screen and fan, but if you don't have screen, you risk
not only dropping something into the fan, but dropping
something into your space behind the panel. No sense loosing
screws and items in there, esp. if they can short something
out.
in the past.
Regards, Jay
bwestfall
PostPosted: Thu Jan 29, 2009 4:33 pm    Post subject: Defrost fan steel mesh filter screens Reply with quote
Jay I ordered these quite a while ago. I've installed them in the forward
fuse but am not yet flying. All I can say as to their effectiveness is they
fit nice and look good.
-Ben
ninepapa(at)bendbroadband
PostPosted: Thu Jan 29, 2009 5:54 pm    Post subject: Defrost fan steel mesh filter screens Reply with quote
And Abby's glare shield covers with fan cutouts include the screens!
John H
robin1(at)mrmoisture.com
PostPosted: Thu Jan 29, 2009 8:02 pm    Post subject: Defrost fan steel mesh filter screens Reply with quote
I purchased an Abby glare shield cover and think it's average looking at
best. The detail around the hand grip made the shield last about 5
minutes on my dash before removing for Plan B.
Robin
Do Not Archive.
PostPosted: Fri Jan 30, 2009 6:39 pm    Post subject: Defrost fan steel mesh filter screens Reply with quote
Robin
I purchased my glare shield cover from Abby at Flight Line Interiors.
The first iteration required some rework which produced an excelent product.
My experience is if there something that is not right, just tell her, and
she will make it right.
PostPosted: Fri Jan 30, 2009 11:24 pm    Post subject: Defrost fan steel mesh filter screens Reply with quote
Good tip, I may do that when back from paint.
Robin
Do Not Archive.
