westexflyboy
Posted: Sun Feb 15, 2009 10:01 pm Post subject: System Objectives |
I have three desired objectives for my RV-10's with dual electronic ignition:
1. Reliability
2. Low pilot workload to manage failures
3. Ability to use radios and EFIS prior to starting the engine (and leave them on during engine start)
Z-14 architecture appears to meet objectives one and two. Z-14 might meet the third objective if I use the main battery to start the engine, the aux battery to power the radios and displays, and I start the engine with the crossfeed contactor open.
Perhaps operating instructions for Z-14 would help - Where can I find those?
_________________ Chase Snodgrass
Presidio, Texas
www.flybigbend.com
Simultaneous RV-10 twins under construction |
andrewbutler(at)ireland.c Guest
Posted: Mon Feb 16, 2009 2:01 am Post subject: System Objectives |
Hello Chase,
On point three, if you bought an EFIS with an internal battery (AFS for example) and installed one or two P-MAGs you could simplify your system significantly and go for a Z13/8 type architecture, With regards leaving the radio on during start, there has been reams of debate on this site in the recent past regarding the real and present or prehistoric need for the "Avionics" switch. Assuming you ditch the Avionics switch and assuming you always maintain your battery properly, will your radio have a tendency to go offline during start? Anyone?
I too liked the idea of Z14 for bullet proof "reliability", but eventually figured it was overkill, so I modified my design, removed the cross over switch etc., replaced the 20Amp Alt with the 8 and eventually ended up with the Z13/8 architecture albeit with a second battery latched on to power my Dual Plasma III. Then I switched to P-Mag/E-MAg ignition, wired up two additional switches (one each for ignition power, and one each for ignition spark) and ditched the 2nd battery.............. All very neat and tidy now and much simpler (and lighter) than the Z14.
Points 1 and 2 are delivered in full by Z13/8.
I can send you the evolution of my diagrams if you wish.
Andrew.
RV7100
Galway, Ireland
Wiring!
rnewman(at)tcwtech.com Guest
Posted: Mon Feb 16, 2009 4:11 am Post subject: System Objectives |
Chase, I have similar objectives for our RV-10. To satisfy requirement
#3 on you list we developed a product called Intelligent Power Stabilizer.
Its available in a 4 amp and 8 amp version and it keeps your EFIS or GPS or
Engine Monitor up and running during engine start without the requirement
for an auxiliary battery. All the details on this and our other products
are available at www.tcwtech.com Notably, Garmin has just finished
testing this series of our products and we are presently working together on
the wiring diagrams for use of IPS products with the Garmin 900x & 530/430
series of products.
Best regards,
Bob Newman
TCW Technologies, LLC.
support(at)tcwtech.com
westexflyboy
Posted: Mon Feb 16, 2009 6:46 am Post subject: Re: System Objectives |
| rnewman(at)tcwtech.com wrote: | we are presently working together on
the wiring diagrams for use of IPS products with the Garmin 900x & 530/430 series of products. |
Bob, are you saying the ICP is ready for Garmin transceivers as is, or are you working on a modified version?
Presidio, Texas
www.flybigbend.com
Posted: Mon Feb 16, 2009 10:07 am Post subject: System Objectives |
Chase,
Our IPS system is done and fully compatable with the Garmin series of
products. We are now in the process of preparing the documentation
including updated instructions sheets and application notes showing the
installation of various Garmin products being powered through an IPS system.
Both IPS products are in stock.
Best regards,
Bob Newman
Posted: Mon Feb 16, 2009 5:46 pm Post subject: System Objectives |
At 12:01 AM 2/16/2009, you wrote:
<airplanedriver(at)gmail.com>
1. Reliability
Consider Z-13/8 with an aux battery added per
Z-30 or Z-35 (leaving aux battery contactor open
during cranking).
Alternatively, you can do Z-10/8 (Z-13/8 with
brown-out protection battery). All these architectures
are shown in Appendix Z, Revision 12A to the 'Connection
found at:
http://www.aeroelectric.com/Rev12A/AppZ_Rev12A.pdf
Someplace in the piles of things-to-do or in-
process is a set of checklists for all the Z-Figures.
I'll see if I can find it an perhaps finish it up.
( -Thomas Paine 1776- )
westexflyboy
Posted: Tue Feb 17, 2009 10:38 am Post subject: Re: System Objectives |
We're planning to use dual LSE Plasma III's and all glass panels, which is why we're leaning toward Z-14. Best I can tell P-mags are not available for the six cylinder Lycoming. (?)
I see my options as follows: install a small battery behind the panel strictly for pre-start ops, or install the IPS device suggested by Bob Newman.
Bob, I am eager to see those checklists.
Presidio, Texas
www.flybigbend.com
mlas(at)cox.net Guest
Posted: Tue Feb 17, 2009 11:50 am Post subject: System Objectives |
Chase,
I run a dual LSE Plasma III and have an all glass panel. I too used a
version of the Z-14 . It's good news that the P-mags are not
available for the 6's, they suck. I just got my 11th P-mag failure in
the field. The out come was good. Plane OK, pilot ok. Engine not so
ok. Timing runaway, CHT's over 600 deg for aprox. 5 minutes on what
was a new engine (not anymore). The pilot had problems with isolating
the mags because of a faulty key switch and was forced to land. I
have seen enough failures to say no to anyone who wants to use this
product, it could cost you your life. I know I'll here the blind
followers that will follow the company and its product into the dirt,
but I care about saving life. Most builders don't understand the
implications of an extremely advanced timing point. It would be
better if the ignition system would just shut off. When the timing go
out of range to the advanced side, it's a single point failure! If
you have your head about you, you may be able to isolate the problem
and secure the faulted system. If you don't you may end up landing
out. Like my last failure, it may be dark. Fortunately he had an
airport nearby. The funny part (sarcasm), this pilot has seen several
failures with his P-mags and has fallen into the trap of just changing
them out. Sooner or later you run out of rope and fate becomes the
hunter. If he chooses to stay with the product one has to wonder what
will happen next. Good luck to all you P-mag drivers, may fate be
your friend.
I know I got a bit off point, but I have taken so much grief from the
P-mag Gestapo that I had to say something.
Back on point, you may find that the second battery will be helpful
for battery starts with fuel injection systems on hot summer days.
Especially if you have dual electronic ignitions installed.
Mike Larkin
Larkin Aviation Consulting
On Feb 17, 2009, at 11:38 AM, westexflyboy wrote:
Chase Snodgrass
Presidio, Texas
www.flybigbend.com
http://forums.matronics.com/viewtopic.php?p 30708#230708
