sschmidt(at)ussynthetic.c Guest
Posted: Mon Mar 27, 2006 10:07 am Post subject: GPS Antenna |
Do you know if there is a minimum distance that GPS antennas need to be spaced if any?
I know COM’s should be at least 30” and transponders should be at least 48” from anything else. But they will work if closer.
Scott Schmidt
Salt Lake City, UT
rvbuilder(at)sausen.net Guest
Posted: Mon Mar 27, 2006 11:19 am Post subject: GPS Antenna |
From each other, nada. Some distance from transmitting antennas is always a good thing but GPS is up in the 1500Mhz band well away from transponder (1050Mhz ish) and our comms (low 100's). GPS is also polarized in a circular fashion so unless they are real close it won't have any effect and even then it probably won't.
Separate them from anything transmitting the best you can and you should be fine.
Michael Sausen
RV-10 #352 Working on Fuselage
Recent RV-10 Build Activity
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Scott Schmidt
Sent: Monday, March 27, 2006 12:03 PM
Subject: GPS Antenna
Scott Schmidt
Salt Lake City, UT
