h&jeuropa
Posted: Sun Feb 15, 2009 5:34 am Post subject: Single Bus |
I am helping a friend with his electrical system. The aircraft is a Velocity, fixed landing gear. The equipment being installed is a pair of GRT EFIS, Garmin GNS430, GTX327 and GMA340 and LED lighting.
Given that the EFIS provides prompt warning of electrical problems, we are wondering if an Essential Bus is really necessary. With the warning from the EFIS, electrical load can be shed quickly (turn off items and go to hand held radio & GPS, airspeed, alt & internal battery powered attitude).
So we are considering a simple system like Fig 17-6 (or Z11 & Z30) without the Essential Bus features (he needs the weight of the batteries for CG reasons). Are we missing something here?
Jim Butcher
Europa XS
N241BW
Posted: Sun Feb 15, 2009 10:07 am Post subject: Single Bus |
At 07:34 AM 2/15/2009, you wrote:
The E-bus is an ENDURANCE bus that not only
congregates those items most useful for battery
only en route continuation of flight that
also provides dual power pathways. One of those
pathways does not require a battery contactor
to be closed (wasted energy equal to about
3 solid state receivers).
Z-11 is no heavier than an off-the-ramp
TC aircraft with an avionics bus. The
E-bus is always recommended if you plan
to venture of cross country . . . and
particularly at night.
( -Thomas Paine 1776- )
bcollinsmn
Joined: 17 Aug 2008 Posts: 23 Location: St. Paul, MN.
Posted: Sun Feb 15, 2009 11:09 am Post subject: What's the future of avionics? |
[quote="nuckolls.bob(at)aeroelect"]At 07:34 AM 2/15/2009, you wrote:
A few weeks ago I tried to get some feedback on approaching these things by way of the Vertical Power system. I didn't see any reaction to it.
When I was at SteinAir a month or so ago for a Minnesota Wing (Van's Air Force) meeting, Stein pointed out that the solid state setup is the future of avionics.
But I don't think I've ever seen this discussed on this board (which, by the way, I consider to be THE single most valuable bulletin board for homebuilders anywhere).
It would be possible -- from what I can gather -- to set up a good backup system, but not without circuit breakers/fuses/switches, which defeats the purpose of the VP system.
I'm just curious how you see this approach to aircraft wiring fitting into some of the excellent advice you provide wrt avionics and electrical system infrastructure?
_________________ Bob Collins
St. Paul, Minn.
RV-7A - Running wires
http://rvbuildershotline.com
Day job: http://minnesota.publicradio.org/collections/special/columns/news_cut/ |
cjay
Posted: Sun Feb 15, 2009 2:08 pm Post subject: Re: What's the future of avionics? |
[quote="bcollinsmn"] | nuckolls.bob(at)aeroelect wrote: | At 07:34 AM 2/15/2009, you wrote:
I'm just curious how you see this approach to aircraft wiring fitting into some of the excellent advice you provide wrt avionics and electrical system infrastructure? |
Bob,
VP recommends an endurance bus as well, same concept as outlined in Z11. Nothing magical about VP, it just replaces the breakers/fuses/switches with solid state technology. I think a lot of people are going to be cautious for awhile because everthing flows through a self contained box. This simplifies design and installation; but a bit of faith is required until people start getting comfortable with the concept. I think they've got a good track record so far.
cjay
Bob Collins
Joined: 11 Mar 2006 Posts: 470 Location: St. Paul, Minnesota
Posted: Sun Feb 15, 2009 2:41 pm Post subject: Single Bus |
Are you sure, cjay? There is a "get home" backup system for the VP-100 and
VP-200
http://verticalpower.com/docs/Backup_Wiring.pdf
But Marc says he's not a fan of it because it introduces several failure
points. And, of course, the VP-200 (and I think the VP-100, too) has its
load-shedding ability configured into the unit itself.
I have a VP-50, one alternator setup. I was trying to figure out how to get
the same benefits that the system in Z-11 affords, but the only system I
could come up with involved a second VP-50 and/or installing a bunch of
CBs/fuses/switches which, as I said, doesn't make much sense because it
introduces components that the VP system should eliminate.
I've just finished the load planning analysis for the VP system. I'm just a
go-up-and-look-down VFR pilot so we're not talking about the kind of
instrument/night flying that Bob mentions in his response to Jim's very
pertinent question. My backup is a hand-held radio. The Dynon has an
internal backup battery and I'm using an AirGizmo-docked GPS which also has
a battery.
I was just curious how folks see electrical systems architecture evolving in
consideration of this.
BTW, I'm very pleased with the people at VP and am very excited to be
working with their product.
An RV-flying pal has three VP-200s in his new RV-10.
St. Paul, Minn.
Letters from Flyover Country
http://rvnewsletter.blogspot.com/ |
marcausman
Posted: Mon Feb 16, 2009 10:31 am Post subject: Re: Single Bus |
Well, first let me say the VP systems do a lot more than just replace switches and breakers. The more advanced the system, the "more" it does. In a nutshell, you get more electrical system features for simpler wiring. Lots of details on our web site so I won't go into it here.
As far as backups, there are multiple levels of backups built into the system. Your backup strategy depends on your mission. A basic VFR aircraft really doesn't need backups, especially if you carry a hand held radio and have an EFIS with backup battery.
However, more advanced aircraft usually incorporate multiple attitude sources, multiple radios, etc. Redundancy or backups in the core electrical system is no different.
We always recommend to customers to install backups for CRITICAL systems (typically EFIS/attitude source, but is determined by the builder) so the pilot can continue safely while in flight. The backup may be an internal battery, or it may be a backup circuit wired directly to the battery bus. This methodology has the VP system as the primary switching system, and a separate and different system to provide backup power to critical avionics. A example for comparison might be having your EFIS as the primary attitude source, and an electric gyro as a backup. This is very common and accepted practice and is the same for the VP system.
_________________ Marc Ausman
http://www.verticalpower.com "Move up to a modern electrical system"
RV-7 IO-390 Flying |
marcausman
Posted: Mon Feb 16, 2009 10:47 am Post subject: Re: What's the future of avionics? |
| cjay wrote: | I think a lot of people are going to be cautious for awhile because everthing flows through a self contained box. This simplifies design and installation; but a bit of faith is required until people start getting comfortable with the concept. I think they've got a good track record so far.
cjay |
We get a lot of calls from people who think there should be no single points of failure anywhere on the aircraft. Actually, there are many single points of failure that will keep you from flying or make you want to land the plane soon (the engine being the most obvious).
From the point of view of your example, the VP is no different than the graphical engine monitors that everyone installs today. If it fails, you are not going flying. You don't just lose one instrument, like you did with steam gages, you lose them all. But the reduced weight, simplified installation, better alarming, higher reliability etc. make that a compelling trade-off and people elect to go with the newer digital systems.
The VP is better in this regard, in that you CAN wire up backups to maintain safety in case of failure.
So, would you go flying if any of these failed on the ground:
- graphical engine monitor
- flap motor stuck down
- single magneto or EI
- prop governor
- brake system
- starter contactor
- battery contacator
- starter motor
Do you have backups for ANY of these installed in the plane?
Just some things to ponder when thinking about new technology. These bridges have been crossed before and you decide whether steam gages/VORs or EFIS/GPS/graphical engine monitors/Vertical Power is the way to go.
l_luv2_fly(at)yahoo.com Guest
Posted: Mon Feb 16, 2009 4:37 pm Post subject: Single Bus |
Hi Jim,
No doubt by now you have seen a number of posts about the advantage of dual path ways that the eBuss configuration offers. As you probably recall I took a lightening hit in my Europa, and among the many electrical things that died in the next few milliseconds was the main contactor.
I can't can't tell you how happy I was when I reached over to that eBuss switch, turned it on and a few essential things sprung into life.
Cheers, Paul
cjay
Posted: Tue Feb 17, 2009 3:20 am Post subject: Re: Single Bus |
| marcausman wrote: | Well, first let me say the VP systems do a lot more than just replace switches and breakers. The more advanced the system, the "more" it does. In a nutshell, you get more electrical system features for simpler wiring. Lots of details on our web site so I won't go into it here.
We always recommend to customers to install backups for CRITICAL systems (typically EFIS/attitude source, but is determined by the builder) so the pilot can continue safely while in flight. The backup may be an internal battery, or it may be a backup circuit wired directly to the battery bus. This methodology has the VP system as the primary switching system, and a separate and different system to provide backup power to critical avionics. A example for comparison might be having your EFIS as the primary attitude source, and an electric gyro as a backup. This is very common and accepted practice and is the same for the VP system. |
Marc,
I didn't mean to undervalue VP, I was trying to put it in perspective. At least at its core it is the solid state devices, but certainly one of your big advantages is once you've gone digital, you've got a vast new potential in software control. Now we get to set our switches and breaker settings like programming our VCR... well maybe that's not a good analogy, I still can't figure how do do mine right...
cjay
frank.hinde(at)hp.com Guest
Posted: Tue Feb 17, 2009 9:57 am Post subject: Single Bus |
Yes that was bizarre..I remember reading the write up.
As one with a totally electrically dependant airplane (albeit a metal airplane) with electric fuel pumps only and dual electronic ignitions who flys in IMC..I REALLY hope it never happens to me..
Cheers
Frank
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Paul McAllister
Sent: Monday, February 16, 2009 4:35 PM
Subject: Re: Single Bus
Hi Jim,
Cheers, Paul
ric-List"'>http://www.matronics.com/Navigator?AeroElectric-List
matronics.com
://www.matronics.com/contribution
longg(at)pjm.com Guest
Posted: Wed Feb 18, 2009 9:54 am Post subject: Single Bus |
Marc,
Thanks for adding the better price point VP-50. That helps fill a bigger
gap. At $6k, I'll rather buy lots of fancy switches and wire, but at
$1500 it may have a chance.
Actually I've already bought lots of switches and wire, so perhaps at
upgrade time.
Do Not Archive.
