Albert Gardner
Posted: Wed Mar 29, 2006 5:55 pm Post subject: Sect. 36-2 Brake Line Fitting Hole In Bottom Skin. |
Well, I should know better by now but following the instructions in step #1,
I drilled the hole in the bottom skin (neat the gear leg opening) for the
brake line fitting before I double checked it. Now I have a 5/8" hole but
the AN837-4D bulkhead 45 only needs a 7/16" hole. I can think of several
ways to fix this but perhaps someone else has blazed the trail here and has
a simple, elegant fix. Any help would be appreciated. Thanks
Albert Gardner
RV-10 40-422
Yuma, AZ
_________________ RV-9A N872RV
RV-10 N991RV |
jim(at)CombsFive.Com Guest
Posted: Wed Mar 29, 2006 6:28 pm Post subject: Sect. 36-2 Brake Line Fitting Hole In Bottom Skin. |
The AN fitting mounts to the landing gear mount, not the skin. The skin was just a clearance hole.
Jim C
#40192
Fuselage
Date: 2006/03/29 Wed PM 08:54:43 EST
Subject: Sect. 36-2 Brake Line Fitting Hole In Bottom Skin.
Albert Gardner
RV-10 40-422
Yuma, AZ
Albert Gardner
Posted: Wed Mar 29, 2006 6:36 pm Post subject: Sect. 36-2 Brake Line Fitting Hole In Bottom Skin. |
That's good news-I was skipping ahead and putting in the brake lines before
mating the firewall and forward cabin parts with the spar carry through.
Albert
RV-10 N991RV |
