Finishing 4130 welded parts
JohnDRead(at)aol.com
PostPosted: Thu Feb 26, 2009 8:06 pm    Post subject: Finishing 4130 welded parts Reply with quote
I was thinking of having the 4130 parts powder coated but I am worried that the oven baking may change the temper of the parts. Is there another method of coating the steel parts that will stand up to wear and tear?
John Read
CH701 - Elbert CO - Jabiru 3300
Phone: 303-648-3261
Fax: 303-648-3262
Cell: 719-494-4567
Get a jump start on your taxes. Find a tax professional in your neighborhood today.
Brady
PostPosted: Fri Feb 27, 2009 12:21 am    Post subject: Re: Finishing 4130 welded parts Reply with quote
John,
The powder coating oven doesn't get hot enough to adversely effect your welded parts. It should only see about 500 degrees momentarily.
Powder coating is good for non moving parts but things like your front gear strut I would go with a chrome plating.
Be sure you tell the Plater to "Bake off the Hydrogen" to avoid embrittlement.
If he doesn't know what you are talking about find another Chrome plater.
Brady McCormick
Poulsbo, WA
www.magnificentmachine.com
ggower_99(at)yahoo.com
PostPosted: Fri Feb 27, 2009 8:49 am    Post subject: Finishing 4130 welded parts Reply with quote
Hello John,
In my factory we have powder coating, I am no expert but can tell you what I have learned in this 20 plus years...
There is no problem with the heat of the oven to the 4130, our is set at 180 ºC (about 356ºF) so will not do any harm. BUT  I did not powder coated the 701 (or the 601XL wea re building) parts, because there is one risk.
A well aplied coat of paint will make a "thick" cover over the material, the paint is more flexible that the 4130, so IF a little crack beguins to develope, the paint will not let you see it in the beguining.
Another thing is I always paint the engine mount white, is easyer to see any cracking even in the beguining.
Hope this helps
Saludos
Gary Gower
Flying from Chapala, Mexico
--- On Thu, 2/26/09, JohnDRead(at)aol.com <JohnDRead(at)aol.com> wrote:
Subject: Finishing 4130 welded parts
To: zenith701801-list(at)matronics.com
Date: Thursday, February 26, 2009, 11:04 PM
John Read
Phone: 303-648-3261
Fax: 303-648-3262
Cell: 719-494-4567
ist" target=_blank rel=nofollow>http://www.matronics.com/Navigator?Zenith701801-List
=nofollow>http://forums.matronics.com
blank rel=nofollow>http://www.matronics.com/contribution
kmccune
PostPosted: Fri Feb 27, 2009 1:50 pm    Post subject: Re: Finishing 4130 welded parts Reply with quote
Its always seemed strange that people paint their mounts white, now I know!
Kevin
do not archive.
“Always do what you are afraid to do.�
R.W. Emerson (1803-1882)
Dorothy McCune
PostPosted: Fri Feb 27, 2009 6:56 pm    Post subject: Finishing 4130 welded parts Reply with quote
Thanks for the replies guys. do not archive.
John Read
Phone: 303-648-3261
Fax: 303-648-3262
Cell: 719-494-4567
