tompkinsl(at)integra.net Guest
Posted: Tue Mar 10, 2009 7:34 am Post subject: IO-360 converted to carbureted |
Does anyone have experience with a 200HP IO-360 that was converted to carburetor fuel system?
It sounds like the only change was to fuel delivery, i.e., the higher compression pistons, 200HP sump and intakes were used. FI was removed and carb installed.
Other than susceptability for carb ice, are there any other disadvantages to this swap? Seems like the engine should still make 200 HP if the installed carb is not a flow restriction.
Larry
| - The Matronics LycomingEngines-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?LycomingEngines-List |
flyinwithme99(at)yahoo.co Guest
Posted: Tue Mar 10, 2009 11:57 am Post subject: IO-360 converted to carbureted |
I'm not sure there is a carb that was jetted and tested at Lycoming for the 200HP IO-360.
I am going to check on this and more details to follow...
From: "Larry L. Tompkins, P.E." <tompkinsl(at)integra.net>
To: lycomingengines-list(at)matronics.com
Sent: Tuesday, March 10, 2009 10:28:42 AM
Subject: IO-360 converted to carbureted
Larry
[quote]h= --> http://www.matronics.com/cont================
jbr79r(at)yahoo.com Guest
Posted: Tue Mar 10, 2009 1:39 pm Post subject: IO-360 converted to carbureted |
Why would you want to go backwards from the advantages of FI to Carb?
James Robinson
Glasair lll N79R
Spanish Fork UT U77
Sent: Tuesday, March 10, 2009 11:56:54 AM
Subject: Re: IO-360 converted to carbureted
Larry
wbecker(at)centurytel.net Guest
Posted: Tue Mar 10, 2009 8:59 pm Post subject: IO-360 converted to carbureted |
Having had FI and carb engines, I would always rather have the FI system.
Bill B
