dlm46007(at)cox.net Guest
Posted: Tue Mar 28, 2006 2:52 pm Post subject: rudder pedal mounting |
The QB fuselage comes with two sets of mounting holes. Which holes are people using? most forward or most aft?
Tim(at)MyRV10.com Guest
Posted: Tue Mar 28, 2006 3:31 pm Post subject: rudder pedal mounting |
I used forward at 6'1 or 2". Works great. My wife at 5'2" can't
use them at all that way. Figure out who's going to fly it
and how tall...that will have an impact.
David McNeill wrote:
| Quote: | The QB fuselage comes with two sets of mounting holes. Which holes are
LarryRosen
Posted: Tue Mar 28, 2006 3:47 pm Post subject: rudder pedal mounting |
5'-10" almost, I used the rear holes. Not flying yet, so I don't know
if they are ok.
Larry
Tim Olson wrote:
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
evmeg(at)snowcrest.net Guest
Posted: Wed Mar 29, 2006 7:48 am Post subject: rudder pedal mounting |
I would think it will depend on your height and leg length. I am an average bear about 5'-9" but my building partner is 6'-1" so I am using the forward set of holes. I would think that the engineers designed this thing for people from 5-5 to 6-2 or so. You will also get the seat rails for adjustments, an advantage that I don't believe any of the other models have.
Cheers...
Evan Johnson
www.evansaviationproducts.com
(530)247-0375
(530)351-1776 cell
jesse(at)itecusa.org Guest
Posted: Wed Mar 29, 2006 8:07 am Post subject: rudder pedal mounting |
Does anybody know how hard it would be to change move the pedals after flying? It shouldn’t be too bad, but you would have to make a new set of holes in the center support.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
I'm in Ecuador right now and should be back in the country by the end of May. You may call me at 352-505-1899 and leave a message that I can check from down here. Any I-TEC questions can be directed to the I-TEC office at 352-465-4545.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Evan and Megan Johnson
Sent: Wednesday, March 29, 2006 10:48 AM
Subject: Re: rudder pedal mounting
Cheers...
Evan Johnson
(530)247-0375
(530)351-1776 cell
bob.kaufmann(at)cox.net Guest
Posted: Wed Mar 29, 2006 6:08 pm Post subject: rudder pedal mounting |
My thought would be to make the center holes so that either position would work and then it would be relatively easy to move it to either position. You could call it a lightening hole if you don’t use it.
Bob K
Putting brake lines on and started doing electrical
PS My Cosmo 20B fully dressed, installed should weigh 420 lbs.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint
Sent: Wednesday, March 29, 2006 8:07 AM
Subject: RE: rudder pedal mounting
Jesse Saint
I-TEC, Inc.
www.itecusa.org
Cheers...
Evan Johnson
(530)247-0375
(530)351-1776 cell
