Max gross weight of 701
dgraham7(at)twcny.rr.com
PostPosted: Wed Mar 18, 2009 3:33 pm    Post subject: Max gross weight of 701 Reply with quote
Hello Group:
I have heard that, under certain circumstances, Zenith has approved a max gross weight above 1100 pounds. Does that have to do with how the plane is flown ?
Damien
larry(at)macsmachine.com
PostPosted: Wed Mar 18, 2009 4:39 pm    Post subject: Max gross weight of 701 Reply with quote
Yes Damien,
Unless you’re flying a Russian YAK (24 +/-Gs), it’s never the day to be
doing hard pull-ups or harsh maneuvers or flying fast in convective air
with a loaded aircraft. It’s not even keen when your total weight is
within the guidelines of specifications. When you fly max weight or even
less, be tender in handling controls even after substantial fuel is
burned off. Your safety net is proportionate to the load you carry, so
always fly with the thought that it matters most to those most critical
parts which includes your butt.
Damien and Kathy wrote:
Hello Group:
plane is flown ?
Damien
jetboy
PostPosted: Thu Mar 19, 2009 12:51 am    Post subject: Re: Max gross weight of 701 Reply with quote
Damien,
The answer is no and yes.
ZAC have not approved any change to the max gross wt. on the 701.
If its an early model, 880 lbs, later, up to Rev.4 , 960 lbs. and after that 1100 lbs. You can upgrade a 960 lbs with the 40 structural parts changes listed in the revision-4 plans.
There is a statement with the plans that details how to calculate the reduction of G loads the airframe will be able to tolerate if the aircraft is OPERATED above the stated max gross wt.
They do not say if the aircraft meets the design rules if operated above max gross, or whether you would be required to calculate and placard the new airspeeds vne, vd, vfe, vs, va.
There is some rumour about additional fuel bays in the wing not being counted as extra load, also amphibian floats being aerodynamic and not part of the calculation, but I have found no approval for this on my plans or in any ZAC CH701 data sheets.
Of course it will fly above design gross, I see many examples doing just that. But as with most aircraft, the main idea is to get to your destination in one piece, with sufficient robustness in the structure to allow for normal wind gusts, build quality and wear. By definition, an Ultralight or Microlight class aircraft means certain safety and durability limits have been pared back to minimums already. No rocket science there.
Ralph
Ralph - CH701 / 2200a
John Bolding
PostPosted: Thu Mar 19, 2009 3:20 am    Post subject: Max gross weight of 701 Reply with quote
Can't speak to the wing tank issue but I did ask Sebastian to clarify the
float weight increase issue and he sang from the Zenith hymnal that the
aerodynamic shape of the floats supports themselves in flight so payload
does not decrease. I didn't swallow this entirely so asked the question of
Chris when I wrote him on several other matters and he repeated the same on
paper. Still have my doubts about the ENTIRE list of moments that can be
generated by the large mass of the floats hanging under the plane in gusts
is of no consequence but I defer to a long history of successful operation
of 701's on floats at above 1200# so I'm still building mine.
LO&SLO John
jetboy
PostPosted: Thu Mar 19, 2009 1:03 pm    Post subject: Re: Max gross weight of 701 Reply with quote
Yes John I'm quite sure the floats wont be a problem.
Interesting to note our NZCAA has entered the registration details of the 2 CH701 which have floats, at MCTOW 544 Kg.
I have seen one of these aircraft up close, and the airspeed limit markings and placards are identical to other CZAW europe spec 701s. (the BCAR specs)
What irritates me is that when I registered my own CH701 the 500 Kg weight was rejected and they placed it at 480 Kg, an impossible figure because no CH701 model was declared compliant with that TP10141e weight category (1058 lbs) I was told that if my weight was entered into the computer all the others would be upgraded and that was the reason.
When I built my 701, another builder thought I should use the Pegastol wings for the same price as ZAC wings, because I would get 125 mph Vne and 1058 lbs weight limits for a stock 110 mph / 960 lbs CH701 airframe. There are a number of these registered as CH701 models here.
Just shows you cannot rely on everything you read even if it is purportedly "official"
Ralph
kmccune
PostPosted: Thu Mar 19, 2009 6:53 pm    Post subject: Re: Max gross weight of 701 Reply with quote
I had posted a smiler question awhile back, and as I understand it( correct me if I'm wrong) you can register it at any weight you want in the US as an EHB? I'm not sure what the insurance would do and I wounder if its best to register at standard gross and do what you have to when you have to??? Like said already your goal is to get to your destination, but its the wording that is s little slippery to me in this case.
I have heard of701s being flight tested at 1300 lbs with out floats.
Kevin
“Always do what you are afraid to do.�
R.W. Emerson (1803-1882)
Dorothy McCune
