sarg314(at)gmail.com Guest
Posted: Sat Apr 04, 2009 4:17 pm Post subject: bolting wings on RV-6A |
I am bolting on the wings for the last time - the electrical system is
done, the engine installed, the fiberglass done and it's even all
painted. I just have to screw it all together, take care of 100
little things and it will fly.
The left gear weldment has about 75% of the bolts in (no nuts on
them) and the rest of the holes in the weldment have locator pins in
place EXCEPT for the two outboard AN3 bolts at the lower edge - right
where the gear leg penetrates the fuselage. These are the most
inaccessible holes. Inserting bolts in these holes from the aft side
of the spar go thru pretty easily and stop hard at the weldment. The
misalignment isn't real obvious, but I can't get the bolts thru or
even drive a tapered pin thru. So, I guess those holes in the
weldment need to be enlarged very slightly.
I could take all the bolts and pins out, remove the weldment and
slightly enlarge or elongate those 2 holes in the weldment and then re-
install. I hate to do all that over again. I noticed that a 3/16
drill bit will slide thru the holes in the spar easily. With a right
angle drill I could just drill out those holes in the weldment. Is
this an acceptable practice, or is it too likely to damage the holes
in the aluminum spar? Or am I barking up the wrong tree entirely?
Almost There....
RV-6A N811WT
ceengland(at)bellsouth.ne Guest
Posted: Sat Apr 04, 2009 4:36 pm Post subject: bolting wings on RV-6A |
thomas sargent wrote:
re-install. I hate to do all that over again. I noticed that a 3/16
Almost There....
RV-6A N811WT
Call Van's.
or
Can you get them in by turning them while putting some pressure on them
to start through the weldment?
or
Call Van's.
(hint, hint)
Charlie
Painless
Joined: 10 Jan 2006 Posts: 40 Location: Peshtigo, Wisconsin
Posted: Sat Apr 04, 2009 4:45 pm Post subject: bolting wings on RV-6A |
I had similar trouble. I just carefully used a reamer and all was
well. Congrats on getting things buttoned up!
Jeff Orear
RV6A N782P
On Apr 4, 2009, at 7:13 PM, thomas sargent wrote:
is done, the engine installed, the fiberglass done and it's even all
in place EXCEPT for the two outboard AN3 bolts at the lower edge -
right where the gear leg penetrates the fuselage. These are the
most inaccessible holes. Inserting bolts in these holes from the
aft side of the spar go thru pretty easily and stop hard at the
weldment. The misalignment isn't real obvious, but I can't get the
bolts thru or even drive a tapered pin thru. So, I guess those
holes in the weldment need to be enlarged very slightly.
3/16 drill bit will slide thru the holes in the spar easily. With a
right angle drill I could just drill out those holes in the
weldment. Is this an acceptable practice, or is it too likely to
damage the holes in the aluminum spar? Or am I barking up the wrong
tree entirely?
Almost There....
RV-6A N811WT
_________________ Jeff Orear
RV6A N782P
Peshtigo, WI |
Posted: Sat Apr 04, 2009 4:50 pm Post subject: bolting wings on RV-6A |
Charlie:
Yes, of course, but I can't call Van's until Monday. I Tried what you
suggest about applying pressure while turning, but couldn't make it
work.
Call Van's.
or
them to start through the weldment?
or
Call Van's.
(hint, hint)
Charlie
AV8ORJWC
Posted: Sat Apr 04, 2009 6:14 pm Post subject: bolting wings on RV-6A |
Use a brass (never steel) drift against the bolt shaft to remove
it/them. Heat the receiver to 200-250 degrees using a Heat/Shrink gun
for about 20 minutes prior to REINSERTION. Place the attachment bolts
in a plastic sandwich bag inside a small six pack cooler with industrial
grade dry ice for at least four hours. The attachment is a "Close
Tolerance" fit. We use liquid nitrogen at work, but unless your girl
friend works for a dermatology clinic on Sunday that will be a stretch
for most builders. Our heat gun can do a constant 950degrees and
beyond. Don't know the wattage of Harbor Freight units.
Patience is a virtue. Good Luck. If they do not go in with less force
you will begin galling of the fastener shaft, scoring and removal of the
cadmium plating. It is easy to read attachment bolts that have been
force fitted during Tech Inspections. Hopefully you used a ream of the
correct size to prep the receiver.
John Cox
bertrv6(at)gmail.com Guest
Posted: Sat Apr 04, 2009 7:23 pm Post subject: bolting wings on RV-6A |
Thomas:
I do not recall, when I built mine, that I could not draw the bolts
in...I know they are very\
tight, but as you they are all close tolerance bolts for ovious reasons...
I would \ not enlarge any holes, I suggest calling Vans, and get a
second opinion, before
going forward,,.
If I recalled, I think I use a heavy, long piece of wood, cut
specifically to fit thru the space,
and then with a heavy hammer, I was able insert the bolts completely,
but I am doing this
by memory, after 6 years....of course they have to be perfectly
aligned, a very little dab of
vaseline, only on thefirst thre or four threads, would help, be sure
to clean them after, before
the nut...
Hope give you some ideas.
good luck.
bert
rv6a
do noat archive
On Sat, Apr 4, 2009 at 8:13 PM, thomas sargent <sarg314(at)gmail.com> wrote:
I am bolting on the wings for the last time - the electrical system is done,
the engine installed, the fiberglass done and it's even all painted. I just
have to screw it all together, take care of 100 little things and it will
fly.
The left gear weldment has about 75% of the bolts in (no nuts on them) and
the rest of the holes in the weldment have locator pins in place EXCEPT for
the two outboard AN3 bolts at the lower edge - right where the gear leg
penetrates the fuselage. These are the most inaccessible holes. Inserting
bolts in these holes from the aft side of the spar go thru pretty easily and
stop hard at the weldment. The misalignment isn't real obvious, but I can't
get the bolts thru or even drive a tapered pin thru. So, I guess those
I could take all the bolts and pins out, remove the weldment and slightly
enlarge or elongate those 2 holes in the weldment and then re-install. I
hate to do all that over again. I noticed that a 3/16 drill bit will slide
thru the holes in the spar easily. With a right angle drill I could just
drill out those holes in the weldment. Is this an acceptable practice, or
is it too likely to damage the holes in the aluminum spar? Or am I barking
Almost There....
RV-6A N811WT
Rick Galati
Joined: 10 Jan 2006 Posts: 91 Location: Lake St. Louis MO.
Posted: Sun Apr 05, 2009 2:35 am Post subject: bolting wings on RV-6A |
--- On Sun, 4/5/09, Rick Galati <rick6a(at)yahoo.com> wrote:
| Quote: | From: Rick Galati <rick6a(at)yahoo.com>
Subject: Re: bolting wings on RV-6A
To: sarg314(at)gmail.com
Date: Sunday, April 5, 2009, 5:31 AM
Tom,
I'd sure be reluctant to ream the holes. The landing gear weldments are attached to the spar mostly with AN3 bolts, NOT close tolerance bolts. The fact is, at some point you did drill those holes through the weldments so at least during the drill out operation those holes did line up.� Note exactly which holes that now don't line up prompting you to post a message. Then, start the installation process all over by removing the fasteners attaching the weldment, including the ones on the fuselage side. When the weldment is completely free, reinstall it by inserting the first AN bolt through a hole that does not now line up. Then, strategically insert a number of the bolts and/or combination of drift pins into a number of holes throughout the weldment leaving all loose. Just barely start a nut on the first thread or two of the bolts and do not run any down until you are sure the mismatch has been worked out.
Rick Galati RV-6A "Darla!"
RV-8
| [quote][b]
emrath(at)comcast.net Guest
Posted: Sun Apr 05, 2009 6:18 am Post subject: bolting wings on RV-6A |
Thomas;
If I understand you correctly, these are not the close tolerance bolts in
the center section. If you end up removing the weldment from the plane, you
can have the holes welded shut, then re-assemble and re-drill the holes
using a drill guide and appropriate reamer.
How are you supporting the ship while you mount the wings?
Marty
Time: 05:17:29 PM PST US
Subject: bolting wings on RV-6A
Almost There....
RV-6A N811WT
Marty Ò¿Ó¬
chris_hand(at)comcast.net Guest
Posted: Sun Apr 05, 2009 8:44 am Post subject: bolting wings on RV-6A |
How do you have the plane supported while doing this?
I had similar problems but was trying to put the remaining bolts in while
the plane was on the gear with only the side bolts and some of the
weldment/spar bolts installed. I was able to resolve by taking the weight
off that main gear when installing those bolts which allowed just enough
shifting of the weldment to allow the holes to line up as originally drilled
a number of years earlier. There was a difference in hole alignment with
weight on the gear as opposed to upside down in the jig without even the
wheels on when the weldments were drilled to the spar.
With the wheel in the air, the methods described in earlier replies worked
for me (turning and/or pressing in).
Chris
RV-6A, almost done with phase I
http://rv6aproject.ckhand.com/
Posted: Sun Apr 05, 2009 8:49 am Post subject: bolting wings on RV-6A |
Marty:
Yes, you are correct. That would work and be the best from an
engineering standpoint. A lot of time and work, though. I think it's
so close already that I'll try a couple other things first.
The ship is supported on the right side by the landing gear installed
with a wooden "false spar" and on the left with a saw horse under the
bottom edge of the fire wall and another under the left rear wing spar
attach point. The left wing is supported by a saw horse out near the
wing tip with a padded, hinged piece on it. It's all freshly painted,
so I have to take care to protect the paint.
On Apr 5, 2009, at 7:16 AM, Emrath wrote:
Thomas;
bolts in
plane, you
holes
Marty
Posted: Sun Apr 05, 2009 8:51 am Post subject: bolting wings on RV-6A |
Sending this again - it went just to Rick and I intended it for the whole list.
Rick:The gear weldments were delivered to me with almost all the holes already drilled. I drilled (or drilled out - it's been years and I don't remember) some of the holes that go thru the side of the fuselage, but none that go thru the spar. The holes for the 2 AN3 bolts I wrote my post about can only be drilled from the rear when the spar is drilled, so these were done by Van's.
I have never understood why the gear weldment holes all line up so poorly. It's as though they drilled them in the steel parts and THEN welded the steel parts together to make the weldment and it warped a bit. I have had to "adjust" nearly all the AN3 holes in the weldment, as I understand most RV-6A builders have. I've had several conversations with van's about this in the past. They just told me to get a small rat-tail file and make them fit. I have never put the 2 AN3 bolts in question in before, so these 2 holes didn't get "fixed".
The method you describe is reasonable and may work, although it would be time consuming; there's lots of different bolt install sequences and there may be some that work better . Adjusting the loading on the gear may shift it slightly too.
I've been at this for 11 years already. I managed to use up that many calendars by doing things in very time consuming ways. Being this close to the end I'd rather not give up any ground unless I absolutely have to.
On Apr 5, 2009, at 3:31 AM, Rick Galati wrote:
| Quote: | Tom,
I'd sure be reluctant to ream the holes. The landing gear weldments are attached to the spar mostly with AD3 bolts, NOT close tolerance bolts. The fact is, at some point you did drill those holes through the weldments so at least during that drill out operation the holes lined up. Note exactly which holes don't line up prompting you to post a message. Then start the installation process all over by removing the fasteners attaching the weldment, including the ones on the fuselage side. When the weldment is completely free, reinstall it by inserting the first bolt through a hole that does not now line up. Then, strategically insert a number of the bolts and/or drift pins into a number of holes along the weldment leaving all loose. Just barely start a nut on the first thread or two of the bolts and do not run any of then down until you are sure the mismatch has been worked out.
RV-8
Posted: Sun Apr 05, 2009 8:55 am Post subject: bolting wings on RV-6A |
Chris:
The wheel is dangling in the air, by only about 1/2", but it's
dangling. The plane's up on saw horses as I described in my last
post. I can put some load on it by shoving a wedge under the wheel.
It also occurred to me that I could deflate the tire, put a thick
board under it and then re-inflate to some degree to adjust the amount
of load it's bearing. I think I'll experiment with that this afternoon.
On Apr 5, 2009, at 9:42 AM, Chris Hand wrote:
while the plane was on the gear with only the side bolts and some of
the weldment/spar bolts installed. I was able to resolve by taking
the weight off that main gear when installing those bolts which
allowed just enough shifting of the weldment to allow the holes to
line up as originally drilled a number of years earlier. There was
a difference in hole alignment with weight on the gear as opposed to
upside down in the jig without even the wheels on when the weldments
worked for me (turning and/or pressing in).
Chris
