Outrigger Length
Troy Maynor
PostPosted: Sun Apr 05, 2009 1:12 pm    Post subject: Outrigger Length Reply with quote
Hi All,
I need information on the OR2 nylon outrigger length. According to the archive in issue 21, page 17, the length should be 315mm between OR1 and OR3. This applies to XS aircraft and Classics with the tailwheel mod. I don't want to trailer it to a large level concrete spot somewhere just yet to get it spot-on. (my drive is gravel and grass). I just want to get it close for now so I can pull it out and start the engine. Would some of you monowheelers measure the distance at the above mentioned spot? I'd like to get a consensus at this point. I'd like to make the final set out of something better than nylon one day.
Troy Maynor
kevann(at)gotsky.com
PostPosted: Sun Apr 05, 2009 1:54 pm    Post subject: Outrigger Length Reply with quote
Troy,
Mine measure 317mm. They both touch on level ground with the plane empty and the tire at about 18psi.
I am testing 1/2 inch fiberglass rod stock going into short nylon bushings in the OR1 and OR3 to see if I can make an outrigger that will have a similar flex but not break. I'll post the results of my tests here.
Kevin
50 hours on Monowheel N211KA so far...
h&jeuropa
PostPosted: Mon Apr 06, 2009 4:10 am    Post subject: Re: Outrigger Length Reply with quote
Troy,
We made them the length that was specified in the build manual. The distance they are from the ground depends on how much the aircraft weighs, and changes with contents - people, fuel, etc. Sometimes they are an inch or two above the ground, sometimes they touch, and sometimes the outriggers bend a little.
Also learned to put the nylon rod and the aluminum fitting in the freezer. Makes assembly easy.
Jim & Heather
N241BW
