rgf(at)dcn.davis.ca.us Guest
Posted: Mon Apr 06, 2009 12:51 pm Post subject: Basic wiring questions |
I have landing/taxi lights, LED nav lights, a Bob Archer VOR antenna, and an
APRS tx/rx antenna in the ends of the wings of an RV-9A (one antenna in each
tip).
1. For the powered items, can I run a single positive wire of adequate size
to a terminal block, then feed the devices from the block?
2. For the antennas, yes they will be using coax, but should I nevertheless
try to run the coax physically separate from the power wires? In addition
to the above power wire I have a 3-wire bundle run from the strobe power
supply in the fuselage to the wing-tip strobe lights. I installed a conduit
about 18 inches away from the Vans wire holes for this purpose.
Ralph Finch
Davis, CA
RV-9A QB-SA
