lwhitlow
Joined: 15 Jan 2006 Posts: 76 Location: Valparaiso Indiana
Posted: Sat Apr 11, 2009 7:40 pm Post subject: Dynon Ammeter Shunt |
Ok one more question
I have a Jab 3300 on my 601 XL i'm using a DYNON EMS-D120
Where should I connect the shunt to be the most useful
Ive seen a diagram floating around showing the various connection options and what you wind up measuring but I can't seen to find it now and I'm hot and heavy into pulling wire.
Thanks in advance
Larry
vshimsl(at)live.com Guest
Posted: Sun Apr 12, 2009 12:06 am Post subject: Dynon Ammeter Shunt |
Your Dynon D180 Manual has a section that gives you three options and explains what each option will show you. I chose option A in my manual. This option shows charge going into the battery as plus amps and charge leaving the battery as negative.
If yours doesn't show you this C then you can download the D180 manual from Dynon.
Regards C
Vince H.
RV8 - Taxi Tests
[quote] Subject: Dynon Ammeter Shunt
Date: Sat C 11 Apr 2009 20:40:09 -0700
--> AeroElectric-List message posted by: "lwhitlow" <ldwhitlow(at)comcast.net>
Thanks in advance
Larry
http://forums.matronics.com/viewtopic.php?p=238745#238745
Windows Live™: Keep your life in sync. Check it out.
