rckol
Posted: Wed Apr 15, 2009 6:14 pm Post subject: Alternator Aux |
I am considering the use of the PlanePower regulator to control a SD-20 alternator. The regulator provides an Aux input that monitors for low voltage (or no voltage due to crowbar trip), but I am told by PlanePower that the expected input for low voltage monitoring is a half voltage (0-7 volt) output from an alternator.
I don't see any such output on the SD-20. Would it be reasonable to produce this half voltage with a simple voltage divider made from a pair of identical resistors between the bus voltage and ground or is there more to this than I am seeing?
_________________ rck |
Posted: Thu Apr 16, 2009 3:29 am Post subject: Alternator Aux |
At 09:14 PM 4/15/2009, you wrote:
You're going to have to has the designer of
the regulator about that. It sounds like their
regulator is designed to exploit the old
"S" terminal that used to grace the back of
many alternators.
The "S" lead was connected to the center
junction of a wye-connected stator winding
and under normal operations this lead produced
an output about 1/2 of system voltage when
the alternator was being turned by the engine.
This output was often used to pull in a relay
that closed the field supply circuit to the
regulator. This feature provided automatic
disconnect of the field when the engine was
stopped. This was a automatic disabling of
the field supply that would prevent an unnecessary
drain on the battery.
I'm mystified as to why they would offer such
a regulator. A few alternator designs on
Wichita piston aircraft had "S" terminals
but to my knowledge, that terminal was never
used as a source for powering an excitation
control relay. I used to build a voltage
sensor that would annunciate a failed
alternator by monitoring the "S" terminal
bit I don't recall it being used any
other way.
I'm thinking the "S" terminal has all
but disappeared from modern alternator
offerings.
Assuming that my hypothesis for their
inclusion of this connection is correct . . .
and assuming further that the regulator
is needing to see this voltage just
to "come alive" then your voltage divider
suggestion may be fine. Or perhaps it just
needs to be jumpered to the field supply
input terminal.
You'll need to ask them about that. Certainly
their STC list speaks to a ton of aircraft
that will not have an alternator fitted with
"S" terminals so they'll have to do something
with that input to the alternator.
( -Thomas Paine 1776- )
rckol
Posted: Thu Apr 16, 2009 7:35 am Post subject: Re: Alternator Aux |
Thanks Bob,
From what I was told, the Aux terminal does nothing but monitor voltage and control the low voltage/overvoltage lamp. So it sounds like it works similar to your voltage sensor that you mention.
This regulator is intended to replace whole catalogs of other regulators, so it probably something provided just for those that use it, although the function has apparently changed somewhat.
If there is no Aux output on the alternator and a voltage warning light is used, the instructions are to jumper the Aux terminal to the field control terminal. In this case, it will only signal an overvoltage condition (after the field breaker is crowbarred). Since the voltage it is looking for is in the neighborhood of 6-7 volts, it is cannot provide a low voltage indication in this configuration (until it is way too late).
I will check with them.
Posted: Thu Apr 16, 2009 4:54 pm Post subject: Alternator Aux |
At 10:35 AM 4/16/2009, you wrote:
Thanks Bob,
Okay, that makes sense.
| Quote: | In this case, it will only signal an overvoltage condition (after
Don't know about the "too late" idea. Using the
aux terminal on an alternator for ANY purpose other
than the original intent of controlling field
excitation is a stretch of design goals.
LV warning should be independent of the regulator
function and have nothing to do with connections
to the alternator. This is how it works in the B&C
regulators. If the regulator you're considering
is NOT fitted with a 13.0 volt threshold LV sensor
then you'll need an external lv monitoring device.
The feature you're wrestling with was never intended
to provide that functionality with precision.
