bdanbish(at)gmail.com Guest
Posted: Mon Apr 13, 2009 9:35 pm Post subject: Bungee Install |
Hi All,
I remember seeing something on here about a slight mod to the installation of the bungee cord, something about cutting it into 2 pieces? Can't find anything on it now, just wondering if there's anyone with more info on this and what the benefit is of doing it.
Dan
Visit - www.EuropaOwners.org
nwcmc(at)tiscali.co.uk Guest
Posted: Mon Apr 13, 2009 10:00 pm Post subject: Bungee Install |
I routed mine so the ends were ar the bottom. The ends are fixed
through eyebolts mounted on the top side of the mono leg. This enables
them to be adjusted for tension from below without removing the
firewall.
Nigel Charles
| Quote: | ----Original Message----
Date: 14/04/2009 6:33
Subj: Bungee Install
Hi All,
http://www.tiscali.co.uk/security - What's your view on the Government's proposal to monitor your Facebook, MySpace, Bebo and Twitter communication?
_______________________________________________________________________
craigb(at)onthenet.com.au Guest
Posted: Tue Apr 14, 2009 3:53 am Post subject: Bungee Install |
I believe some of the guys also ran the bungee as a series gaint rubber
bands, which allowed each one to be adjusted, and tension was controled
by adding or removing as required. Not sure how the ends were fixed though.
craig
rick(at)amimotormanagemen Guest
Posted: Tue Apr 14, 2009 7:03 am Post subject: Bungee Install |
Dead easy. We used little wire 'u' clamps available from any DIY place.
After about 200 hours on a very bumpy strip I'm thinking of maybe adding
another (10 minute job) but it's been no problem. There will be all the
details in the archives.
Cheers
Rick Morris
G-RIKS Tri 912S
Posted: Tue Apr 14, 2009 11:11 am Post subject: Bungee Install |
Thanks guys, I'll look into it.
