toaster73(at)embarqmail.c Guest
Posted: Fri Apr 17, 2009 4:14 pm Post subject: Inside surface finish of engine cowl |
Wondered what folks are doing as far as priming/painting/coating the inside of the engine cowlings, I have the pink ones.
Chris
#40072
egohr1
Joined: 17 Jan 2006 Posts: 38 Location: Oklahoma City
Posted: Sat Apr 18, 2009 4:40 am Post subject: Re: Inside surface finish of engine cowl |
For what it is worth. I painted the inside of the cowl with the same epoxy primer I am using for the outside of the plane. Dupont Colar expoy, seems to be tough as nails.
eric
_________________ eric gohr
EGOHR86@alumni.carnegiemellon.edu |
AirMike
Posted: Sat Apr 18, 2009 7:02 am Post subject: Inside surface finish of engine cowl |
Good idea to paint it with epoxy primer. Also not a bad idea to put some of the adhesive aluminum sold by Vans to protect the composite from the heat of the aluminum. I just ordered some 6'x 30" runs about $40. This makes it a lot easier to clean and gives some protection from the heat and oil penetration. It will get oily inside.
_________________ See you OSH '18
Q/B - sold. |
dlm46007(at)cox.net Guest
Posted: Sat Apr 18, 2009 10:37 am Post subject: Inside surface finish of engine cowl |
There is a fiberglass mat with a silicone back that can be RTVed in place.
This was need to keep the heat from turning the Sherman Williams Spread and
Spray epoxy primer from turning light tan in color.
