zeprep251(at)aol.com Guest
Posted: Fri Apr 24, 2009 2:21 pm Post subject: Kolb-List: 503 low CHTâs dilemma! |
Mike,
What puzzles me is why your full throttle egts are higher than cruise egts.At full throttle you should be seeing egts under 1100. Does the carb slide move all the way up at full throttle? It should be clear of the bore by about 1/4 inch so that last bit of travel does nothing but pull the needle out to its richest position.A lightly loaded prop should make the chts low but the egts higher.
My 503 ran 500 hrs and only saw 300 cht once or twice.
Good luck G.Aman
ropermike
Joined: 28 Aug 2006 Posts: 40 Location: West Texas, South Mississippi
Posted: Fri Apr 24, 2009 6:16 pm Post subject: Re: Kolb-List: 503 low CHTâs dilemma! |
I dont understand it either! I do have new needles and needle jets coming. Maybe that will make a difference. I will check on the carb slide travel to make sure I'm getting fulll throttle in the morning. Thanks for the help, Mike
_________________ The next best thing to playing and winning is playing and losing!...Mike Hillger |
