Guy Buchanan
Posted: Fri Apr 24, 2009 2:03 pm Post subject: Newbie questions, which easier to fly a Kitfox or a CH 701 |
At 12:15 PM 4/24/2009, you wrote:
| Quote: | Im looking into the Zenith CH 701 or maybe a kitfox, for my needs
what do you guys think is best?
I want a Rotax 912 in the nose on either plane.
That's easy. Kitfox all the way. (After all, this IS the Kitfox
forum.) Seriously, though, you've got to fly them yourself. There's
no way to tell otherwise.
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 300 hrs. and counting
Deceased K-IV 1200
A glider pilot too. |
dave
Posted: Sat Apr 25, 2009 2:39 am Post subject: Re: Newbie questions, which easier to fly a Kitfox or a CH |
I have a friend with a 701 912 ul .
I have a kitfox 582 that is faster cruise and take offs not much different. His angle of climb a bit steeper.
He wants to travel further and faster and just finished a Sonex with jab 3300.
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Guy Buchanan
Posted: Sun Apr 26, 2009 8:39 pm Post subject: Newbie questions, which easier to fly a Kitfox or a CH 701 |
At 11:50 AM 4/26/2009, you wrote:
| Quote: | So vortex generators are made /tested and sold by the Kitfox factory? or is just an aftermarket product?
Is not totally tested yet? |
Hi,
I think I missed your name. Here on the Kitfox list we encourage you to put your full name, location, and aircraft status/type in your signature.
I think Lowell will tell you that VG's have been rather thoroughly tested on Kitfoxes with little improvement shown. (See the archives for lots of talk and a little data.) What HAS been shown to work is leading edge slats. We had one fellow claim stall speeds in the 20's. What I want to see is someone install the slats made by Turbine Cubs of Wyoming. These are free-floating slats that supposedly dramatically reduce stall speeds while reducing top end very little.
Guy Buchanan, Kitfox List Moderator
San Diego, CA
K-IV 1200 / 582-C / Warp / 300 hrs. and counting [quote][b]
Deceased K-IV 1200
Float Flyr
Posted: Mon Apr 27, 2009 9:18 am Post subject: Newbie questions, which easier to fly a Kitfox or a CH 701 |
Vortex generators are made by many different firms. They are used on just about every large aircraft going. Vortex generators and wing fences are easily seen on the DHC-2 Otter. The idea is if you can cause tiny vortices to form on the top of the wing then the air passing over the wing will remain intact with the top of the wing at steeper angles of attack giving more lift at slower speeds. Obviously there is a point of diminishing returns.
The most important factor of installing vortex generators is to find the right spot on the wing chord to place them. Generally this is around 10% chord but may be as far aft as thickest point of the chord.
Dave has installed vortex generators to the bottom of his cowl. They cause more air to pass through his radiator for better cooling. Others have put them on the bottom of the horizontal stabs where they give more elevator control in the flare.
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Guy Buchanan
Sent: Monday, April 27, 2009 2:02 AM
Subject: Re: Re: Newbie questions, which easier to fly a Kitfox or a CH 701
Hi,
San Diego, CA
K-IV 1200 / 582-C / Warp / 300 hrs. and counting | Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 0123456789
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
