clint_bazzill(at)hotmail. Guest
Posted: Sun Apr 26, 2009 2:57 pm Post subject: Newbie questions, which easier to fly a Kitfox or a CH 701 |
Lowell C
I have done very careful testing with my Kitfox Model IV. I have not done a complete evaluation but will tell you this. My aircraft stalls with vortex generators clean at the same speed with full flaps without. Indicated C calibrated C and gps ground speeds. Also took videos tuffed wing before installing them.
Clint
[quote] From: lcfitt(at)sbcglobal.net
Subject: Re: Re: Newbie questions C which easier to fly a Kitfox or a CH 701
Date: Sun C 26 Apr 2009 11:24:23 -0700
Mike C
FYI C and this has been mentioned many times on the list C often by very
careful observers - vortex generators do very little to stall speed
reduction with the Kitfox wing - in most instances not measureable. Control
stability is almost universally reported C but no effect on stall speed.
All this despite what we all know about vortex generators.
I have heard some talk on this and it just might be that the Riblet airfoil
Kitfox uses is not a true airfoil as the design profile only exists at the
fuel tank C rib caps C the false ribs and maybe three inches at the wing tip.
A total of about four feet on each wing. The rest is a different profile
because of the depression due to the fabric shrinking between the ribs and
false ribs. Harry Riblet tells us that the most critical point on this
airfoil is the first five inches. This is exactly where the leading edge
cuff and spar give away to the collapsed fabric. There are several
airplanes currently being built with "D" profile leading edges that will
protect the leading edge shape and these might benefit from vortex
generators. But the proof will be in the testing rather than the hoping.
Lowell
dave
Posted: Sun Apr 26, 2009 5:41 pm Post subject: Re: Newbie questions, which easier to fly a Kitfox or a CH |
Clint , when you say full flaps - how many degrees is that ?
Early models only got 10 to 15%
IV went past 30 degrees . mine go to 33 degrees and only useful for taking off quicker. I usually land with 20 degrees flaps in full stall 3 pointer
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Posted: Sun Apr 26, 2009 8:53 pm Post subject: Newbie questions, which easier to fly a Kitfox or a CH 701 |
The handle is straight up. ? degrees
Clint
[quote] _=====
dave
Posted: Mon Apr 27, 2009 9:30 am Post subject: Re: Newbie questions, which easier to fly a Kitfox or a CH |
Clint i think some use a limiter on their flapperon handle.
I do not , mine deploy 33 degree when the handle is straight up on Model IV. Works excellent for takes offs but over 20 degrees flapperons are useless for landing plus you lose alot of roll control.
| Quote: | [quote="clint_bazzill(at)hotmail."]The handle is straight up. ? degrees
Clint |
it
