				 Posted: Wed May 13, 2009 2:49 am    Post subject: Getting the right prop |
				Ron C
    Evidently C as BB pointed out in his most diplomatic way C the Rotax 912 swings a prop CCW.
  Boyd made the distinction that this was "in pusher configuration".  He was pretty diplomatic C too.
    Therefore C here's how it looks to me;  I have a GEO engine.....with a belt drive.  It has a left turning prop.  You have a GEO engine......with a gear drive.  You will need a right turning prop.
    It might be best to not look at it as "the same prop as a Rotax".  In various configurations an engine will turn a prop different ways (as Boyd pointed out).  What matters most is the universal
  accurate rotation description........if you stand at the back of the plane C and you watch the prop spin C does it spin clockwise?  If it does C then it is a right turning prop.  If it spins CCW C then you got a lefty.   So C in your case C you have the identical engine/redrive combo as Michael Sharp C and would need a right turning propeller.
  Mike Welch
  MkIII
 Insert movie times and more without leaving Hotmail®. See how.  [quote][b]
  |  | - The Matronics Kolb-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		captainron1(at)cox.net Guest
				 Posted: Wed May 13, 2009 3:45 pm    Post subject: Getting the right prop |
				I have no clue Mike, I have yet to install a prop or start the motor. But if I can get it clear in my head which prop I need, and then someone has that type of prop for sale with a price I can afford then I think I am going to buy it.
 I may just email Vassily and have him tell me what prop I need, I am sure there will not be any questions after that.
 So far and correct me if I am wrong, my understanding is that a Rotax 912 prop will turn in the direction my Geo + SPG2 needs it to turn so I can in the direction its supposed to go.
 Ron (at) KFHU
 ---- Mike Welch <mdnanwelch7(at)hotmail.com> wrote:
 Ron,
   Evidently, as BB pointed out in his most diplomatic way, the Rotax 912 swings a prop CCW.
 Boyd made the distinction that this was "in pusher configuration".  He was pretty diplomatic, too.
   Therefore, here's how it looks to me;  I have a GEO engine.....with a belt drive.  It has a left turning prop.  You have a GEO engine......with a gear drive.  You will need a right turning prop.
 accurate rotation description........if you stand at the back of the plane, and you watch the prop spin, does it spin clockwise?  If it does, then it is a right turning prop.  If it spins CCW, then you got a lefty.   So, in your case, you have the identical engine/redrive combo as Michael Sharp, and would need a right turning propeller.
 Mike Welch
 MkIII
 Insert movie times and more without leaving HotmailĀ®.
 http://windowslive.com/Tutorial/Hotmail/QuickAdd?ocid=TXT_TAGLM_WL_HM_Tutorial_QuickAdd1_052009
 kugelair.com
