jlsk1(at)frontiernet.net Guest
Posted: Sat May 23, 2009 5:44 pm Post subject: Bing Carb Problem FYI |
Hi All,
For what its worth, I though I`d share a recent problem & solution with a Bing carb I had this week. It all started last Sat, when after a short flight in my MK3C 912 bird, one of my bing 64 carbs started leaking after engine shutdown. It quit after a minute or so, but not after scaring the bejeebers out of me, cuz the fuel was boiling off of a hot exhaust pipe!
Once it quit, & cooled down for a few miute, I thought, I`d better be sure where it was coming from. I turned on the electric fuel pump & the carb bowl instantly was wet & dripping again.
Since it was hot outside, & in the hangar, & the engine was still hot, I left the airport ticked off, thinking I`d research the possible problems & check out solutions.
Not knowing that much about bing 64s, I asked a few of my fellow Kolb drivers their opinions, and, once I learned more, Agreed that it must be a sticking float needle & or float bowl gasket.
Didn`t get to get back to it until Tuesday, & had a helper flip on the fuel pump again & after repeated checks, found that it was the Brass fitting that the fuel line attached to! This wasn`t a threaded in fitting like on the new carbs, but a "pressed in fitting" (Pressed in according to the folks at BING in Kansas)
LOOOONg story short, (I know, too late, its already long), the folks at Bing, L. E. A. F. & Lockwood, have never seen this before & each had a different recommendation. The bottom line was this, that fitting was not just pressed in, but was inserted with an "O"-ring. The O-ring was letting fuel pass by. Once I got the fitting out, found that it was a Nickel fix, re-inserted it a new o-ring with some green Locktite ( LEAF Recommended), I enjoyed a 15 minute check flight yesterday, & 1.2 hours today.
I also bought the fuel drip pan kit from CPS & will install it shortly .
Some of you may have already known of this O-ring deal before, but Since Bing & LEAF & Lockwood didn`t, I thought I `d pass it along.The folks with thread-in fittings have an advantage, cuz the seal will be easier to replace.
Jim Kmet
Cookeville TN
MK-3C 912
MK-3C 582
by0ung(at)brigham.net Guest
Posted: Sun May 24, 2009 6:48 am Post subject: Bing Carb Problem FYI |
Quote: | >>>>>>>>>>>>>>>>>>>..
How did you get it out without destroying it?… was it loose, or did it take a bit of twisting and pulling? What kind of o ring did you use? All orings are not made of the same material, was what you used suitable for use with gas?
Boyd Young
MKIIIC
Utah
Posted: Sun May 24, 2009 12:51 pm Post subject: Bing Carb Problem FYI |
Boy I hope it`s compatable with gas, now you`ve prompted me to do some more research on the other ones in this o-ring stash that it came from.I got it out by having a helper securly hold the carb on a work bench, & I put a short pc of fuel line over the nipple to cushion & protect it. Then held it just below the flare with a unique pair of pliers that when clamped, held close to the same diameter as the pipe nipple, & tapped the Pliers with the hammer, away from the carb body, & after a few Raps, it popped out.
now on to research to make sure I put a gas compatable o-ring on it. If not, I gotta do it again, thanks for the heads up on the o-rings.
Jim
Thom Riddle
Posted: Sun May 24, 2009 1:13 pm Post subject: Bing Carb Problem FYI |
Here is a fluid compatibility guide for o-ring materials that may help you.
http://www.allorings.com/compatibility.htm
Thom in Buffalo
On Sun, May 24, 2009 at 4:50 PM, Jim Kmet <jlsk1(at)frontiernet.net (jlsk1(at)frontiernet.net)> wrote:
[quote] Boy I hope it`s compatable with gas, now you`ve prompted me to do some more research on the other ones in this o-ring stash that it came from.I got it out by having a helper securly hold the carb on a work bench, & I put a short pc of fuel line over the nipple to cushion & protect it. Then held it just below the flare with a unique pair of pliers that when clamped, held close to the same diameter as the pipe nipple, & tapped the Pliers with the hammer, away from the carb body, & after a few Raps, it popped out.
Jim
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
Posted: Sun May 24, 2009 1:52 pm Post subject: Bing Carb Problem FYI |
Thanks for the chart, they are NBR & according to this chart, they are recommended for gasoline. Jim
Thom Riddle
Posted: Mon May 25, 2009 2:42 am Post subject: Re: Bing Carb Problem FYI |
Glad to help.
On a related subject, according to this material compatibility chart, the Viton tips on the float valves in Bing 64 carbs on 912 engines is rated only Marginal for Ethyl Alcohol. So those of us flying with 912 engines should keep close eye on these valves if we are running ethanol laced autogas.
Buffalo, NY (9G0)
- Anonymous |
Posted: Mon May 25, 2009 6:44 am Post subject: Bing Carb Problem FYI |
Jim
Posted: Mon May 25, 2009 6:47 am Post subject: Bing Carb Problem FYI |
Jim
lucien
Posted: Mon May 25, 2009 7:56 am Post subject: Re: Bing Carb Problem FYI |
Thom Riddle wrote: | Glad to help.
On a related subject, according to this material compatibility chart, the Viton tips on the float valves in Bing 64 carbs on 912 engines is rated only Marginal for Ethyl Alcohol. So those of us flying with 912 engines should keep close eye on these valves if we are running ethanol laced autogas. |
great.... and here I was thinking Rotax approved 10% with no restrictions including the carburettors.
I'd take that to mean the carburettor parts should still last their normal lifetimes, but we can't let the maintenance slip as long as before .
FWIW, I'm on my 3rd tank (maybe 4th) of 10% premium with no running problems or problems with the fuel system. So far no vapour lock or even so much as a burp even up to about 9000'. I guess it'll be years from now before I could find out about any corrosion problems or shortened lifetimes of carburettor rubbers.
Time to order my carburettor overhaul kits anyway....
LS
_________________ LS
Titan II SS |
