		jeffyork40(at)qx.net Guest
				 Posted: Sun Mar 26, 2006 10:07 am    Post subject: a little rough, a little miss @ low RPM |
				My Great Plaines 2180 VW has a little miss at low RPM 1100 or less. What I might call a bit of a stumble miss but very slight. By 1500 RPM or better, everything seems fine.
 It seems to me that it has always done this but I will ask for advice giving you as much information as I can.
 Running a single mag ignition, autolite automotive plugs ( they are the substitute for the Bosch WA 8 plugs GPAS calls for) narrow gap .028 per Steve Bennets book., Zenith Carb, K&N cone filter.
 As I mentioned, it seems to me it has always done this but I am wondering if some day on final , I go to pull the throttle back and it quits on me. So I will also mention that I am burning off some older Av gas, many months old as the plane has been under various stages of getting it back together.
 Also, just a little note of interest. I just had Jet Hot ceramic coat my 4 into one exhaust. They do it inside and out verses others who only do the outside of the exhaust.
 Anyway, since the exhaust coating, I can now peg the tach past 3500 RPM verses previously getting 3200 RPM and maybe on a rare perfect day getting around 3400 RPM. I mention the Jet Coating since that is the only thing I did to the engine and then getting a sudden increase in RPM. Yes the days right now are cooler but the engine has 56 hours and has run on many cool days before.
 Jeff York
 Lexington, KY.
 KR-2 Flying
 N839BG
 Home page  http://web.qx.net/jeffyork40/
 My KR-2       http://web.qx.net/jeffyork40/Airplane/   to see my KR-2
 Email             jeffyork40(at)qx.net
  |  | - The Matronics KR-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?KR-List |
		JEHayward(at)aol.com Guest
				 Posted: Sun Mar 26, 2006 6:33 pm    Post subject: a little rough, a little miss @ low RPM |
				In a message dated 3/26/2006 11:07:52 AM Mountain Standard Time,
 jeffyork40(at)qx.net writes:
  	  | Quote: | 	 		   My Great Plaines 2180 VW has a little miss at low RPM 1100 or less. What I
        Jeff, you'll probably get much more help over on the
        KRNet list than here.... hardly anything ever shows
        up here.
        Jim Hayward
        Rapid City, SD
