First Flights was Pilot Proficiency vs RV10 'flyabil
glastar(at)gmx.net
PostPosted: Thu May 28, 2009 5:39 am    Post subject: First Flights was Pilot Proficiency vs RV10 'flyabil Reply with quote
Jim,
a good advice seen in the LAA publication, if you have a configurable
system declutter the screens and have only the minimal information
shown, later on add features and get used to it. At least with the cheap
Dynon that is an option
br Werner
jim(at)CombsFive.Com wrote:
Les,
I had transition training with Alex in Dallas. He made sure to cover
the emergency landing piece of flying! I felt pretty good on the
first flight. Just don't expect to do a lot on the first flight.
Gary brought up a good point. If you are not used to the EFIS
screens, you can be overwhelmed by the amount of information
presented. It takes a while (Several hours of flying) to get used to
what you need to look and and what can be ignored. Spending time on
the ground with the systems up and running goes a long way before
actually getting in the air and wondering what buttons to push to get
this and that to happen.
Jim C
N312F - It's a wonderful airplane to fly!
Hi
This thread and the various perspectives are interesting to say the least.
I'd like to add a twist related to first flights especially given all the
newly minted -10s that have been taking off of late.
When the time comes to take my -10 up, I will be current in my PA28 and
will
also have taken transition training. That being said, the first flight
really seems to me to be a flight into the unknown. Sure everything will
have been quadruple checked but then again, sometimes s**t does happen. At
that point experience will count for everything. Although I have a 1000+
hours in my Cherokee, I have never had an off field landing (touch wood)
or
a serious emergency.
That being said, my plan was to get a pilot experienced in initial flights
to do the first test flight. What happens if something goes seriously
wrong
on the initial flight? Are we builders, especially after reduced flying
hours due to building, really the best people to fly the initial flight?
Even factory built a/c are test flown by skilled *test* pilots for the
first
time. Just food for thought.....
Cheers
Les
#40643 KOSH 20xx or bust
Tim Olson
PostPosted: Thu May 28, 2009 8:13 am    Post subject: First Flights was Pilot Proficiency vs RV10 'flyabil Reply with quote
I was VERY paranoid about how I'd transition to an EFIS from steam
gauges for my first flight. I went into it figuring I may not
even look at the EFIS much because it wouldn't be as easy to
read and understand. Turns out I was wrong. I found that the
transition went really smooth, almost immediate. Now, if you're
talking about the "How do I load approaches" and that kind of thing,
that's a whole different story. But, just being able to view
and quickly interpret the EFIS...that wasn't bad at all. Just
try not to turn on every item of clutter that you have, and
keep it simple.
The BIGGER headache is going for that first flight with all of
your alarm limits not tuned in. I had my stall warning set
intentionally high (probably shouldn't have done that), and
some other limits set in places that I later adjusted. I
didn't know what to expect, so I guess at their set points.
So on my first flight, I was getting stall warnings when I
was far from a stall....I just flew by feel. In retrospect,
if there had only been more flying RV-10s back then it would
have been nice to just copy what someone else had for limits
and go with it for the first flight, being realistic on that
stall speed. (I had mine set for 75kts or something like
that).
I had spent a bit of time not only sitting behind the
powered up screen, but playing with the simulator on the
PC before I flew, so it wasn't totally from ground zero.
One bit of warning though.... if you have devices like
heading indicators and other things that require calibration,
or scaling, do that before your first flight. Way too
many people seem to skip it and then they end up with
some unusual avionics issues that they wouldn't have had
to deal with.
Tim Olson - RV-10 N104CD
Les,
the emergency landing piece of flying! I felt pretty good on the first
Gary brought up a good point. If you are not used to the EFIS screens,
you can be overwhelmed by the amount of information presented. It takes
a while (Several hours of flying) to get used to what you need to look
and and what can be ignored. Spending time on the ground with the
systems up and running goes a long way before actually getting in the
air and wondering what buttons to push to get this and that to happen.
Jim C
Hi
will
or
wrong
first
Cheers
Les
