sarg314(at)gmail.com Guest
Posted: Thu Jun 04, 2009 8:15 am Post subject: removing nose gear wheel. |
How do people normally prop up the plane to remove the nose wheel and fairing (6A/7A)? During construction I've been using the engine hoist, but I'm in final assembly now and have to remove the lifting eye from the engine. Is it OK (or even possible) to put a scissors jack under the end of the nose gear? Is there a better way ?
Tom Sargent, RV-6A final assembly
Bret Smith
Joined: 09 Jan 2006 Posts: 178 Location: Mineral Bluff, GA
Posted: Thu Jun 04, 2009 8:54 am Post subject: removing nose gear wheel. |
I have someone push down on the rear fuse while I put 3-4 2x4's under the nosegear nut.
Bret Smith
RV-9A N16BL
Blue Ridge, GA
www.FlightInnovations.com
_________________ Bret Smith
RV-9A (Emp) |
Larry Bowen
Posted: Thu Jun 04, 2009 9:19 am Post subject: removing nose gear wheel. |
Some have used sandbags on the root end of the HS to make the nose very light. IE, lift it with one hand.
Why is it necessary to remove the "lifting eye" from the engine? It will be used again someday. I've never heard of it being taken just because your ready to fly...
Larry Bowen
Larry(at)BowenAero.com
http://BowenAero.com
Sent from Welcome, NC, United States
On Thu, Jun 4, 2009 at 12:40 PM, Bret Smith <smithhb(at)tds.net (smithhb(at)tds.net)> wrote:
[quote] I have someone push down on the rear fuse while I put 3-4 2x4's under the nosegear nut.
Bret Smith
RV-9A N16BL
Blue Ridge, GA
_________________ Larry Bowen
RV-8 SOLD,
RV-7QB in progress... |
garrys(at)tampabay.rr.com Guest
Posted: Thu Jun 04, 2009 10:00 am Post subject: removing nose gear wheel. |
I drilled a hole in the concrete floor of my hanger and installed a heavy duty eye bolt............directly underneath the tail tie down ring. Then I bought a cheap ratcheting strap with two hooks on each end and I simply ratchet the tail down until the nose gear is off the ground. Works great for nose wheel and fairing maintenance.
Garry Stout
flying RV-7A
jim jewell
Joined: 09 Jan 2006 Posts: 82 Location: Kelowna B.C. Canada
Posted: Thu Jun 04, 2009 1:47 pm Post subject: removing nose gear wheel. |
Tom,
I use a low profile automotive hydraulic floor jack.
A 3/8" thick piece of plywood is used to protect the threads on the end of the nose gear strut. A temporary protective plug made out of tough plastic could be made if the use of a lathe is available.
Jacking this way has become a bit easier to do with the advent of the new added nose wheel leg ground clearance height.
The hydraulic jack allows for very fine axle/fork height adjustment so that the axle bolt can be slipped in or out of place with the wheel just resting on the ground.
Jim in Kelowna
_________________ "I never make mistreaks" |
kahamer(at)bigpond.net.au Guest
Posted: Thu Jun 04, 2009 2:04 pm Post subject: removing nose gear wheel. |
Put a sling onto the engine mount and lift it there.
Karl 7A
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of thomas sargent
Sent: Friday, 5 June 2009 2:13 AM
To: rv-list(at)matronics.com
Subject: removing nose gear wheel.
Tom Sargent, RV-6A final assembly | Quote: | | http://www.matronics.com/Navigator?RV-List | 0123456789
No virus found in this incoming message. Checked by AVG - www.avg.com 270.12.52/2153 - Release Date: 06/03/09 18:00:00 [quote][b]
JohnInReno
Posted: Thu Jun 04, 2009 2:29 pm Post subject: removing nose gear wheel. |
I use a Harbor Freight motorcycle lift to raise all 3 wheels at onece:
http://picasaweb.google.com/lh/photo/cpM5MJHMDgu9ZoQwA1yAOw?feat=directlink
John Morgensen
AA1B - flying
RV9A - wiring
_________________ John Morgensen
RV-9A - Born on July 3, 2013
RV4 - for sale |
denis.walsh(at)comcast.ne Guest
Posted: Thu Jun 04, 2009 4:39 pm Post subject: removing nose gear wheel. |
I use a couple sandbags on the horizontal stab.
Good rule of thumb. Don't never use the engine lifting eye for anything other than lifting the engine! Even then be sure it is "free". If you tear out a chunk of the engine case it will ruin your whole day.
I have also used someone pushing down on the tail while I shove some blocks under the nose strut.
It is my personal opinion that the belly skin is not a good choice for hoisting the plane. Maybe ok with a Grumman Iron Works plane, but not an RV-6A. If you want to try that one, I would run it by the structures guys at Van's .
On Jun 4, 2009, at 10:13 , thomas sargent wrote:
[quote]How do people normally prop up the plane to remove the nose wheel and fairing (6A/7A)? During construction I've been using the engine hoist, but I'm in final assembly now and have to remove the lifting eye from the engine. Is it OK (or even possible) to put a scissors jack under the end of the nose gear? Is there a better way ?
href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
| [b]
seiders(at)bellsouth.net Guest
Posted: Thu Jun 04, 2009 6:06 pm Post subject: removing nose gear wheel. |
Get someone to push down the tail and place a sawhorse under the fuse
just behind the xhaust stacks.
At 12:13 PM 6/4/2009, you wrote:
| Quote: | How do people normally prop up the plane to remove the nose wheel
Posted: Sat Jun 06, 2009 6:51 am Post subject: removing nose gear wheel. |
Larry:I'd like to leave the lifting eye on the engine, but I made fiberglass cooling plenum for the engine and the eye won't fit underneath it. In fact I don't think it will fit under the cowl either, for that matter.
On Jun 4, 2009, at 10:15 AM, Larry Bowen wrote:
[quote]Some have used sandbags on the root end of the HS to make the nose very light. IE, lift it with one hand.
Why is it necessary to remove the "lifting eye" from the engine? It will be used again someday. I've never heard of it being taken just because your ready to fly....
Larry Bowen
Larry(at)BowenAero.com (Larry(at)BowenAero.com)
