Fuel tank quantities.
dlm46007(at)cox.net
PostPosted: Fri Jun 05, 2009 10:14 am    Post subject: Fuel tank quantities. Reply with quote
Has anyone filled a completely empty tank to determine volume. After calibrating the fuel totalizer in phase I. I find that several fill ups indicate that the actual volume of the standard tanks is about 31 gal per side. Any confirmation? I am sure the calculus wizards at Vans have the answer but they have not answered my inquiry yet? It would be extremely unlikely that the computed volume (at standard temps) would be exactly 30 gals
bcondrey
PostPosted: Fri Jun 05, 2009 10:51 am    Post subject: Fuel tank quantities. Reply with quote
It is indeed a little over 30.
Bob
N442PM
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill
Sent: Friday, June 05, 2009 1:01 PM
Subject: Fuel tank quantities.
dlm46007(at)cox.net
PostPosted: Fri Jun 05, 2009 11:27 am    Post subject: Fuel tank quantities. Reply with quote
Another observation.fuel just covering the floor of the tank at the filler opening is about 6-8 gallons. a straw type stick can measure anything at 8+ gallons at the tank filler. Mine is graduated at 10,15,20,25,30. Just to confirm the cruising capabilities of the 10. My return from CNW to FFZ was about 800NM in 5:05 and a total burn of 45 gallons. There was a miniscule tailwind westbound. TAS ranged from 148 to 157 KTAS faster as I got lighter. Flight was at 12000 and 55%. 20"" and 2250 RPM and -10 to -25 F LOP; the burn was about 8.8 gph. CHTs high 20s to low 300s. EGTs high 1300s.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Condrey, Bob (US SSA)
Sent: Friday, June 05, 2009 11:42 AM
Subject: RE: Fuel tank quantities.
Bob
N442PM
0 [quote][b]
Tim Olson
PostPosted: Fri Jun 05, 2009 11:47 am    Post subject: Fuel tank quantities. Reply with quote
31 is almost exactly what I was able to fit in mine.
Tim Olson - RV-10 N104CD
exactly 30 gals
gengrumpy(at)aol.com
PostPosted: Fri Jun 05, 2009 1:02 pm    Post subject: Fuel tank quantities. Reply with quote
I did a "calibrated? paint stick and filled from empty to 30 gal in 10 gal increments. Works great as my GRT fuel flow transmitter is off a bit (reads slightly higher than actual - on the safe side).
grumpy N184JM
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Condrey, Bob (US SSA)
Bob
N442PM
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of David McNeill
http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.com
= [quote][b]
