xponder ant mounting
woxofswa
PostPosted: Sat Jun 06, 2009 10:55 am    Post subject: xponder ant mounting Reply with quote
Since I already installed a reinforcement plate into the floor of my tailcone to mount my ground power receptacle, is there any reason that I can't mount my transponder antenna into the same plate an inch or two from the piper plug receptacle?
Thanks in advance. I am loathe to drill holes into my skin without checking first.
Myron Nelson
Mesa, AZ
Flew May 10 2014
PostPosted: Mon Jun 08, 2009 6:26 am    Post subject: xponder ant mounting Reply with quote
checking first.
I see no structural problems with it . . .
One usually mounts the xponder antenna
on the belly centerline. I presume your
ground power jack structure is off to one
side. I doubt that an off-center antenna
location is any big deal.
( -Thomas Paine 1776- )
rv8iator
PostPosted: Tue Jun 09, 2009 5:45 am    Post subject: xponder ant mounting Reply with quote
Bob et al...
While on the subject of xponder antennae... I am helping with wiring of a Kitfox (rag & tube) and we need to mount a xponder antenna. IIRC the antenna requires a ground plane 12 inches in diameter. Is this correct? The xponder frequencys are 1030 and 1090Mhz which is a wavelength of about 291mm and 275mm or about 12 and 11 inches. I would think I would tune for the lower freq as the higher would be inclusive.
A 12 inch diameter aluminum plate with the antenna monted in the center is my plan... please feel free to educate me further!
Thanks...
Chris Stone
Newberg, OR
Rv's 'n' Kitfox's
C. Stone (RV8iator)
PostPosted: Tue Jun 09, 2009 2:51 pm    Post subject: xponder ant mounting Reply with quote
At 08:40 AM 6/9/2009, you wrote:
Bob et al...
The "ideal" ground plane has a radius equal to
the height of the antenna. I.e., about 2.6" for
a transponder.
Anything bigger, such as the 12" diameter is not
a "tuned" ground plane in which case make it any
size you wish. Anything bigger than the 2.6" radius
is not going to significantly alter performance.
