occom
Posted: Tue Jun 30, 2009 2:25 pm Post subject: spacer at rear of cockpit roof- info needed |
Due to the unusual configuration of my rear window I must place a wide strip of aluminum over the rear of the cockpit roof which extends over the one piece rear window plastic. I may not wish to keep the arrangement and I want to make provision for returning to the folding window. (if anyone has a folding window for sale now would be a good time to speak up).
In order to do that I must replace the spacer that goes between the roof and the support, but I do not know how thick it is or the original material. My original Denney manual gives no specs for many pieces, just part numbers.
lcfitt(at)sbcglobal.net Guest
Posted: Tue Jun 30, 2009 4:25 pm Post subject: spacer at rear of cockpit roof- info needed |
Dave,
You caught me at the perfect moment. I am in the process of straightening
up my hangar for a 4th of July breakfast here. Along with that project is
an attempt to sort through the parts for my new (1992) Model IV kit. The
part you are wondering about is .025 thick. The turtle deck is .020. The
piece I have is cut a bit shy of half inch. If you can't find such a piece
locally, I have a bit of scrap and should be able to send what you need for
postage.
Lowell
occom
Posted: Tue Jun 30, 2009 5:05 pm Post subject: spacer at rear of cockpit roof- info needed |
Thanks Lowell, I can come up with enough .025 to make it. The top piece I'm
using is just soft aluminum and weighs 5 oz. on top of the very heavy
window, not ideal and I expect to remove it later on.
