rob10(at)tlb.sympatico.ca Guest
Posted: Fri Jul 03, 2009 3:23 pm Post subject: Throttle cable |
I probably need to replace the throttle cable on me Kitfox 4 - 912 engine. Mine is bent at the carb link point and I have a hard time to do the carb synchronisation.Do you guys have a good place to order this cable? Any advise on what to avoid and what to look for?
Jack
Kitfox 4 - 1200- Rotax 912
wannafly
Posted: Fri Jul 03, 2009 5:55 pm Post subject: Throttle cable |
Check out www.bullyhawk.com They make an amazing throttle cable. It is some new weave of cable that when you push on it outside of the cover it actually straightens out instead of bending. very neat stuff.
mic
Subject: Kitfox-List: Throttle cable
Date: Fri C 3 Jul 2009 19:20:39 -0400
Jack
| Quote: | http://www.matronics.com/Navigator?Kitfox-List
ronics.com
ww.matronics.com/contribution
| Attention all humans. We are your photos. Free us. [quote][b]
lcfitt(at)sbcglobal.net Guest
Posted: Sat Jul 04, 2009 5:40 am Post subject: Throttle cable |
Jack, I had replaced this cable several times and always just used cable
from the local hardwqare store. As I recall it was 1/16 SS cable. Not
perfectly sure, though. With essentially no bends, I never thought that
the internally lubricated aircraft cable was necessary.
Lowell
jdmcbean(at)kitfoxaircraf Guest
Posted: Sat Jul 04, 2009 7:54 am Post subject: Throttle cable |
Jack,
We have a very nice twin lead throttle cable. Eliminates the bellcrank.
Fly Safe !!
John & Debra McBean
Ph 208.337.5111
www.kitfoxaircraft.com
"The Sky is not the Limit... It's a Playground"
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of rosane beaule
Sent: Friday, July 03, 2009 5:21 PM
Subject: Throttle cable
Jack
| Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 0123456789
Jim Feldmann
Posted: Sat Jul 04, 2009 8:32 am Post subject: Re: Throttle cable |
Jack:
I went through the same thing when I needed to replace the choke cables. I just needed to replace the inner cable, since the sleeves were OK. The cables I bought locally and online proved to be too stiff and the chokes wouldn't shut off completely.
I learned that there are different "weaves" (not the real term) available and the way the cable is "woven" affects it's flexibility. The common 1/16" cable is 1 x 16. It is too stiff to use in any application that requires a bend (as the choke cables do). I had to use 7 x 7 cable to make it work.
You may get away with the 1 x 16 on the throttle, but I would recommend the 7 x 7 for that use as well. I think it would give you a little more leeway if you get a kink or some foreign material in the sleeve.
I think I bought the 7 x 7 cable from Leading Edge Airfoils.
_________________ Jim Feldmann
Kitfox IV Speedster / 912 lost to prop failure
Building a Kitfox 5 Voyager |
clint_bazzill(at)hotmail. Guest
Posted: Sat Jul 04, 2009 8:49 am Post subject: Throttle cable |
I replaced my cables at least once for the choke. I went to a good local bicycle store and purchased it C no problem
Model IV 1450 hours.
Clint
[quote] From: lcfitt(at)sbcglobal.net
Subject: Re: Throttle cable
Date: Sat C 4 Jul 2009 06:33:42 -0700
--> Kitfox-List message posted by: "Lowell Fitt" <lcfitt(at)sbcglobal.net>
Jack C I had replaced this cable several times and always just used cable
perfectly sure C though. With essentially no bends C I never thought that
Lowell
Dick Maddux
Posted: Sun Jul 05, 2009 3:39 am Post subject: Throttle cable |
Jack,
I bought my throttle cable replacement from Lockwood. It was very reasonable and they sell either the cable or the sheath. If you have the "old" bellcrank,as I have, you can then use Highwing LLc's "throttle bug" which makes carb syncing a piece of cake ! (you pneumatically sync one carb to the other with a turn of a knob-takes all of about 30 seconds !)
Dick Maddux
Fox 4-1200
912 UL
Pensacola,Fl
Make your summer sizzle with fast and easy recipes for the grill.
andynfultz(at)bellsouth.n Guest
Posted: Sun Jul 05, 2009 6:15 am Post subject: Throttle cable |
Mic,
It must be in some super secret hidden link. I couldn't find it when I went to their site.
Andy F.
[quote] --
wannafly
Posted: Mon Jul 06, 2009 8:15 am Post subject: Throttle cable |
yes I noticed that. try calling Bob directly. I was at his shop 2 weeks ago and he was making some up for RV aircraft at the time.
mic
Subject: RE: Throttle cable
Date: Sun C 5 Jul 2009 09:12:38 -0500
.ExternalClass .EC_hmmessage P {padding-right:0px;padding-left:0px;padding-bottom:0px;padding-top:0px;} .ExternalClass BODY.EC_hmmessage {font-size:10pt;font-family:Verdana;} Mic C
Andy F.
[quote] --
