dlm46007(at)cox.net Guest
Posted: Fri Jul 03, 2009 4:26 pm Post subject: Tool kit |
I sometimes joke that I can handle anything short of an engine overhaul or
wing removal. I carry:
a 1/4 and 3/6" drive sets
Spark plug socket
combo wrenches from 1/4 to 7/8"
Mechanical and magnetic grapplers
Slotted and Phillips head 1 and 2
needle nose and vise grip pliers
safety wire and pliers
Four small trays of additional fasteners and tie wraps
Small and normal size dikes
Voltmeter with leads and extra alligator clip jumpers
Avionics removal tool
Forceps both straight and curved
Allen wrenches both English and metric
Misc caps and plugs for fluid/air lines
Other small one off items that escape memory
Also I carry separately the gust locks, tie down lugs and Plexus, a couple
of spare plugs and contactors
I would have to borrow tools for a sheet metal repair.
Lastly I carry a USB memory stick with all the airframe pdf plans, install
manuals, operation manuals etc (893MB)
taildragon(at)msn.com Guest
Posted: Fri Jul 03, 2009 7:09 pm Post subject: Tool kit |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> This is a great topic. We all do plenty of maintenance to prevent a problem away from home. The items in the suggested tool kit probably came to mind because of possible problems, from experience or imagined. What are the top ten "most likely" problems that you might foresee? I'll start the list:
1. Low or flat tire
2. Dead battery
3.
Posted: Fri Jul 03, 2009 8:36 pm Post subject: Tool kit |
tools are needed to disassemble the airframe; on a recent tip my son drop his thumb drive while touching the right stick. Bad luck. The thumb drive could no be found and I had to remove the right seat and the inspection panel under it to get the offending item. That required removing the rear torque tube cover and the front seat lock mechanism bolts. It was nice to have the tools to do this at hand rather than borrowing from the FBO or my host.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Roger Standley
Sent: Friday, July 03, 2009 7:58 PM
Subject: Re: Tool kit
1. Low or flat tire
2. Dead battery
3.
vhicy(at)bigpond.com Guest
Posted: Fri Jul 03, 2009 9:59 pm Post subject: Tool kit |
We are just finishing a 3 week outback Australia flying holiday.
We have taken everything bar the kitchen sink. What we have used so far
Torch
Safetey tie wire
Somewhere to store front spat after it gets broken on bush strip (soooo thats why no bush planes here have spats!).
Lots of oil . About 1 Quart every 7 hours. Hope that is not to much.
Chris VH-ICY Stuck in Parkes NSW (where the movie The Dish was made) due to rain.
AV8ORJWC
Posted: Sun Jul 05, 2009 9:25 am Post subject: Tool kit |
David, you haven't mentioned that you found the Thumb drive. Had this same thing happen at OSH with a stubby phillips screwdriver last year. After a full field strip, the owner admitted he forgot and stowed it elsewhere. Got a steak dinner out of the lost six hours of inspection panel removal/reinstallation. Just finished an annual with an owner that had a hand-held extinguisher that would slide forward and block control rod movements. Think Safety!
Be ready on trips to tackle the unexpected.
John Cox
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill
Sent: Friday, July 03, 2009 9:35 PM
Subject: RE: Tool kit
1. Low or flat tire
2. Dead battery
3.
Posted: Sun Jul 05, 2009 10:11 am Post subject: Tool kit |
Yes he found his thumb drive under the right front seat; probably would not have cause any problem but I never like to leave tools or other extraneous material floating around in the aircraft.
another spare that is carried is one master contactor and one starter relay, since most of these aircraft are dependent on electrons flowing.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Cox
Sent: Sunday, July 05, 2009 10:22 AM
John Cox
1. Low or flat tire
2. Dead battery
3.
----- Original Message -----
Sent: Friday, July 03, 2009 5:24 PM
Subject: Tool kit
--> RV10-List message posted by: "David McNeill" <dlm46007(at)cox.net (dlm46007(at)cox.net)>
Spark plug socket
