seipel(at)seznam.cz Guest
Posted: Sun Apr 02, 2006 8:57 am Post subject: Dimensions for the F1044B angle |
On page 31-2, revision 0, of the plans, step 2 is to fabricate the
F1044B Angle. The plans give the overall length of the part, but so far
as I can tell, there is no dimension on the drawing that allows me to
determine the length of the piece on the left side that gets bent
upwards. Am I missing it somewhere?
PJ
#40032
LarryRosen
Posted: Sun Apr 02, 2006 10:18 am Post subject: Dimensions for the F1044B angle |
I have a quickbuild fuse, so the part was already manufactured and
installed. However the upper forward fuselage is off the plane. I
measured the part and the short flat section is 1/4" and the bent
section is 3/4" of an inch. I will send you photos of list.
Larry
PJ Seipel wrote:
far as I can tell, there is no dimension on the drawing that allows me
to determine the length of the piece on the left side that gets bent
PJ
#40032
http://wiki.matronics.com
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
Rick S.
Posted: Sun Apr 02, 2006 4:44 pm Post subject: Dimensions for the F1044B angle |
PJ,
The drawing in the plans is to scale, cut your notch 3/4" back in the angle. Polish is up and make your bend. Go easy, it may seem hard to bend but it went pretty easy. I clamped mine in the jaws of my hand seamer and slowly worked it to the reverse angle of 31 degrees, it was easier to measure than 149 degrees.
Rick S.
40185
Fuse & Finish
_________________ Rick S.
RV-10
40185 |
