stokesc(at)wildblue.net Guest
Posted: Wed Jul 15, 2009 9:16 pm Post subject: 582 gasket set on Ebay |
Is it possible to use the gaskets again after dismantling
the engine after 3 hours use.
There are brand X gasket sets sold on Ebay for about half
what Rotax sells them. Are they good replacements or
just junk and not worth the savings?
Cecil
kitfox 4 1050 582 C
akflyer
Posted: Thu Jul 16, 2009 8:14 am Post subject: Re: 582 gasket set on Ebay |
I have been using them with no issues.. 300 hrs on one engine and about 50 on each of the other 2. just DO NOT use the pistons that he sells. They are junk. Learned this the hard way when we had one engine partial failure, and a total failure in mine (I made the runway with a 20 knot tailwind and about 1' to spare). In both cases the rings collapsed and resulted in 0 compression. Darn thing does not run too well that way..
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
napierm(at)cisco.com Guest
Posted: Fri Jul 17, 2009 6:13 am Post subject: 582 gasket set on Ebay |
The aftermarket gaskets are OK. I ran them with no problems. The only
ones I didn't use are the large crankshaft seals. The ones from Rotax
are much better.
To save over $50 these are the same as the ones on ebay and are what I
ran:
http://www.mfgsupply.com/m/c/711194.html
You still wind up buying a couple of odd seals from Rotax but this kit
will save you at least $150.
Also, if you just need to do a top end this one is a great deal:
http://www.mfgsupply.com/m/c/712194.html
Also, for the odd o-ring buy them from:
www.amseal.com
The vast majority of the o-rings are just buna-N and the only reason
they are so high is that they come through Rotax distribution. For
instance, there are over $70 worth of o-rings in the starter mount
alone. Most of these you can get from Amseal except of a couple of
strange ones for much less. And these o-rings need to be there, fresh
and the 1mm clearance set or the starter mount will break.
FWIW,
Mark Napier
Time: 09:16:43 AM PST US
Subject: Re: 582 gasket set on Ebay
50 on each
junk.
total
to
compression. Darn
DO NOT ARCHIVE
Soldotna AK
Avid "C" / Mk IV
582 IVO IFA
Full Lotus 1450
hander outer of humorless darwin awards
http://forums.matronics.com/viewtopic.php?p 53351#253351
