tdawson-townsend(at)auror Guest
Posted: Sun Aug 09, 2009 7:42 am Post subject: Trim indicator |
All:
Testing the trim (Safety-Trim) and trim indicator (Ray Allen), I got just one lit bar, at the far end of the indicator range. (can’t tell yet whether it’s the “up” or “down” end) Checking things, somehow I was applying 24 volts to the indictor power! I fixed that, but the result is the same.
Do you think I “toasted” the indicator and now it will only show that one lit bar at the end of the scale, or is there some debugging I can do between the three signal wires from the trim servo? I looked for some info from Ray Allen on debugging at that level, without success.
I figure RAC will answer my question on Monday, but thought I would try the list in case anyone has some insight there.
TDT
Tim Dawson-Townsend
40025
tdt(at)aurora.aero (tdt(at)aurora.aero)
617-500-4812 (office)
617-905-4800 (mobile)
rbibb
Posted: Sun Aug 09, 2009 8:11 am Post subject: Trim indicator |
You might have fried some of the individual LEDs.
If you apply 12V directly to the indicator input line all LEDs should light.
I don’t have the indicator schematic handy but that is how I recall it is wired.
When you applied 24V you got twice the current going through the elements. Depending on how long and the current capacity of the diodes they might e OK. At least one of them is….
Richard Bibb
972-771-2598
972-835-5979 mobile
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dawson-Townsend,Timothy
Sent: Sunday, August 09, 2009 10:38 AM
Subject: Trim indicator
All:
TDT
Tim Dawson-Townsend
40025
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 0123456789
Posted: Sun Aug 09, 2009 4:41 pm Post subject: Trim indicator |
Does the trim actually move but the indicator does not?
I went out and tested the POS-12 for my flaps and was able to get the
indicator to move as I moved the trim itself, however it stayed in one
position when the trim was not powered/working.
could be a matter of calibrating it as well, if it's on the EFIS or
other component.
Pascal
On Sun, 2009-08-09 at 11:38 -0400, Dawson-Townsend,Timothy wrote:
| Quote: | All:
result is the same.
TDT
Tim Dawson-Townsend
40025
tdt(at)aurora.aero
