Tim Olson
Posted: Sat Aug 22, 2009 7:18 pm Post subject: LOP (Lean of Peak) Injector Tuning |
For those who are interested in running LOP and who want to
get better injector tuning to make their engine run smooth
when Lean of Peak, I wrote up my recent experience in tuning
the injectors. It was cheap, and very very easy.
http://www.myrv10.com/N104CD/upgrades/20090822/index.html
There will be a future update to the write-up, as I'm working
on a project on another engine, but the info here should give
you what you need to get started tweaking your own system.
It's so simple that there's no reason not to get your engine
set up for great operation.
Tim Olson - RV-10 N104CD
540 hours and climbing
Tim Olson
Dick Sipp
Posted: Sat Aug 22, 2009 8:58 pm Post subject: LOP (Lean of Peak) Injector Tuning |
Tim:
Great post as usual on your injector balancing experience. I had very
nearly the same experience and results with two minor variations; a complete
Airflow Performance system vs. your Silver Hawk and we started by installing
.026's in all cylinders and then balancing. I ran most of the tests at
10-11 MSL and verified at the results at 7.5. Don R. felt that at the lower
power settings of around 50-60% the flow divider begins to be the
determining factor and by going to the smaller .026s the flow divider is
taken out of the equation.
There was an interesting series of pictures and notes regarding burned
pistons (don't remember where I saw them) where the author thought the cause
was "rapid" mixture leaning used by LOP operators. He felt the rapid rise
in EGT was the cause. I disagree. GAMI recommends the "big pull" from rich
to LOP and then a finer adujustment to prevent spending more time in the
danger zone of peak to 100 rich of peak. Also with a rapid initial mixture
leaning I doubt the cylinder or piston temp will increase before it cools
from steady LOP operation. Further at <65% I do not think you can do
anything to the mixture that would harm or overstress the engine.
Regarding long range cruise I was happy to find that my engine seems equally
smooth at 2250 as at higher RPM. I see about a 1GPH reduction in fuel flow
with each 100 RPM reduction at full throttle settings and there is very
little airspeed loss as the prop is taking bigger bits (sorta like
overdrive). Charles Lindberg showed the P-38 pilots in the South Pacific how
to double their range by running "over square and lean". Finally, to
prevent the prop driving the engine during higher speed descents I keep the
RPM at least "2" oversquare below manifold pressure. This is common
practice with the big radials and it would seem equally applicable to our
engines.
Dick Sipp
N110DV 175 hours
speckter(at)comcast.net Guest
Posted: Sun Aug 23, 2009 4:10 am Post subject: LOP (Lean of Peak) Injector Tuning |
Is there a danger with running too much over square? Dick mentions 2" but I
have been running more than that (2200 and 26")LOP. I have not seen much
info on running over square.
Gary Specketer
N777TY
Joined: 09 Apr 2006 Posts: 69 Location: Charlotte, NC
Posted: Sun Aug 23, 2009 6:33 am Post subject: Re: LOP (Lean of Peak) Injector Tuning |
Dick,
I think you're referring to this document:
http://www.eci.aero/pdf/93-6-7.pdf
(though, no photos in it..)
_________________ RV-7A
N777TY |
AV8ORJWC
Posted: Sun Aug 23, 2009 6:44 am Post subject: LOP (Lean of Peak) Injector Tuning |
The challenge is to avoid Detonation and the earlier than planned
destruction of the engine. That can be a factor of compression ratio of
the cylinder, quality and octane of the AVGAS, carbon and garbage
deposits inside the combustion chamber and the ignition event. The
lower the RPM, the higher the throttle the greater the risk.
Several pilots are running upward of 10.0:1 pistons, choose their avgas
supplier wisely, run a well timed ignition system and gently increase
the throttle. GAMI has made a business of educating pilots. Others try
marginal gas quality, ragged ignitions and throw caution to the wind.
Choose wisely. Fly Safe. Check your % of power tables for LOP
operations.
John
Deems Davis
Posted: Sun Aug 23, 2009 7:24 am Post subject: LOP (Lean of Peak) Injector Tuning |
All of the LOP information is GREAT. Keep it coming !!!!!!! I have a
question:
When leaning the engine, the 'old traditional / prior to gages' way was
to lean it until it begins to 'stumble' and then richen it up a bit.
When I lean using the EGT gages I notice the 'stumble' when the 1st
cylinder goes lean. If you continue to lean until all of the remaining
cylinders peak (LOP), What happens to the 'stumble' ??? Does it even out
/ go way with the engine running smooth? Does it persist? Since any
changes in the engines smooth running are a concern in flight, I'd
appreciate learning what those of you that are routinely running LOP are
experiencing.
Deems Davis N519PJ
http://deemsrv10.com/index.html
Gary Specketer
billderou(at)yahoo.com Guest
Posted: Sun Aug 23, 2009 8:46 am Post subject: LOP (Lean of Peak) Injector Tuning |
I believe tuning the injector nozzles will create a smoother running engine and that in itself has value. However, I have been mystified during these conversations as to the value of running LOP vs fuel economy. There was never enough data in the emails to get the whole picture. The question I always had was how much speed are you willing to loose to gain how much fuel efficiency?
Thanks to Dave's pic of his panel and my own experience I was able to put a picture together.
The following numbers are in statute miles and the Density Altitude is similar. If we assume that the top speed of our RV-10's is 205mph then Dave is flying 20% (164.5smph) under max and achieving 18.6smpg while leaned to approx 25deg LOP. An averaged flight in my plane is 6% under max speed (193smph) achieving 19.1smpg while leaned to peak. My definition of peak is when 3 cylinders drop.
Typical panel setup for me is: WOT, 10-13K feet, 2380-2420rpm, 10.1-10.3gph, lean to peak.
These are only two datapoints. What are others achieving? And please provide the whole picture - what is the percent under max speed you are willing to fly and the miles per gallon you are achieving as a benefit. I assume the whole LOP (other than a smooth engine) is to achieve fuel efficiency.
What am I missing?
Bill DeRouchey
N939SB
--- On Sun, 8/23/09, Deems Davis <deemsdavis(at)cox.net> wrote:
Subject: Re: LOP (Lean of Peak) Injector Tuning
Date: Sunday, August 23, 2009, 8:22 AM
--> RV10-List message posted by: Deems Davis <deemsdavis(at)cox.net>
All of the LOP information is GREAT. Keep it coming !!!!!!! I have a question:
When leaning the engine, the 'old traditional / prior to gages' way was to lean it until it begins to 'stumble' and then richen it up a bit. When I lean using the EGT gages I notice the 'stumble' when the 1st cylinder goes lean. If you continue to lean until all of the remaining cylinders peak (LOP), What happens to the 'stumble' ??? Does it even out / go way with the engine running smooth? Does it persist? Since any changes in the engines smooth running are a concern in flight, I'd appreciate learning what those of you that are routinely running LOP are experiencing.
Deems Davis N519PJ
gary wrote:
[quote] --> RV10-List message posted by: "gary" <speckter(at)comcast.net>
Gary Specketer
Tim Olson
Posted: Sun Aug 23, 2009 9:16 am Post subject: LOP (Lean of Peak) Injector Tuning |
This is just a guess, for me, to answer your question, but first
I'll pass on what my experience has been...
When I lean up to and past peak, there is never a period where
it stumbles. It keeps running smoothly and as you get further
and further LOP, you can hear the engine start to lose power...
it gets quieter. If you run that way for a couple minutes and
adapt to the sound, you will easily hear and feel the extra
power come back as you richen it up towards that -25 to -50F
LOP again...and feel even more power as you richen it back to
ROP operation. The old "lean to stumble" works well with the
carbureted planes I guess. (In my opinion though if it's
really that non-precise, carbureted engines in general are
kind of "sloppy", and not really going to be nearly as
good for LOP) Probably everyone should be using a 6 probe
monitor for their operations.
So my opinion on the answer to the question would be...since
you're running a fuel injected engine, if it's stumbling
when it gets to peak on one cylinder, I would guess (just
a guess) that it won't go away as you keep leaning further.
It would probably be the case that something is preventing
you from getting it smooth...be it timing, compression, or
something else. The hope is that you can determine what
exactly that is, and then make it work so it is smooth.
This is the big headache for me in the later part of that
writeup. My pal with the 10:1 pistons, we really have to
apply ourselves to figure that one out. He ordered the .026
injectors, so we'll see soon how that plays out. Maybe that
would be all it would take for you too. I'm hoping that we
can make it perfect and then provide more info to all others
who face the same hurdle.
I am just finally able to get to replying today, and I've
gotten a couple of great offline emails. One of them
brought up something that I should mention that is
important and I'll add this warning into the write-up soon.
I wrote there that you should use a timing light to time
both systems. This is something basically being said by
Klaus at Lightspeed. Of course, it's in his interest to
urge you to be very precise in determining timing. It would
be ideal if you knew it exactly. But, timing a system with
a timing light, being up by the prop when it's moving,
is a very dangerous thing. The writer, and A&P himself, said
that static timing of a mag can be very good. I agree.
I felt like a slacker that I've never used a timing light
on my plane, but I feel my mag was timed pretty well by
standard simple static timing. But, in this extreme case
of this 10:1 engine, I'm not sure what to do. Klaus
says use a timing light and get it exact...then tweak
the systems or maybe just the mag, and do some testing...try
advancing a little. I don't know what to say but...BE
CAREFUL if you're working near a moving prop....take it from
Stein.
Also, I assumed that with higher compression you would need
to slightly retard the timing. That may not be the case.
Klaus said LOP sometimes works better with advanced timing.
Anyway, he said not to use the adjustable timing knob addition
on the lightspeed..it's too dangerous to mess with. But,
the one big thing he did say that makes perfect sense is
to READ THE INSTALLATION MANUAL AND FOLLOW THE DIRECTIONS.
So, we're also going back into the Lightspeed install and
going to make sure the engine is set up properly per that
manual.
Wish it was simple answers for everyone, but there are going
to be some unique cases, with the various engine setups.
question:
experiencing.
Deems Davis N519PJ
> but I
> Gary Specketer
coop85(at)verizon.net Guest
Posted: Sun Aug 23, 2009 10:54 am Post subject: LOP (Lean of Peak) Injector Tuning |
Bill,
You address an interesting question. The primary debate has been on whether to choose the old school Rich of Peak (ROP) or Lean of Peak (LOP) which is why the big fuel savings over slight airspeed drop numbers. Seems that most of us were taught to either richen slightly after the engine stumbles in the absence of good gauges, or run around 50 to 100 ROP depending on cruise or power requirements. Your choice to go at peak certainly accomplishes most of the LOP intent of saving gas without the speed drop.
I have read on the forum somewhere that some companies actually recommend running at peak, whereas I’ve also read some concerns over that setting so I’m hopefully there are some educated answers out there. My overall understanding is the key is to keep the CHTs under control and otherwise where you set the mixture shouldn’t do any damage provided you are under 65% power. Amazing how what should be a fairly straightforward topic has so many perceptions.
I for one have been very please with LOP and really appreciate Tim’s write-up as I would like to make it even better. I have the same setup and stayed clear of tweaking because I didn’t know we had the same injector options as the Airflow Performance setup, so THANKS.
Marcus
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill DeRouchey
Sent: Sunday, August 23, 2009 12:38 PM
What am I missing?
Bill DeRouchey
N939SB
Deems Davis N519PJ
> Gary Specketer
taildragon(at)msn.com Guest
Posted: Sun Aug 23, 2009 1:21 pm Post subject: LOP (Lean of Peak) Injector Tuning |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Yes, I find this subject interesting, too.
I have a question: What are you seeing for peak EGT at various power settings, say at 75%, 65% and 55% power settings?
Roger
Kelly McMullen
Posted: Sun Aug 23, 2009 2:50 pm Post subject: LOP (Lean of Peak) Injector Tuning |
Peak depends on a lot of factors besides power setting...OAT,
altitude, exact probe placement, type of instrument, etc. I've seen
anywhere from 1400 to 1500 peak on the IO-360 in my Mooney. I have
UBG16 with fast acting probes mounted 1.5" below exhaust port flange.
I try to climb at 1200-1250F EGT, but don't obsess on it.
On Sun, Aug 23, 2009 at 2:19 PM, Roger Standley<taildragon(at)msn.com> wrote:
[quote] Yes, I find this subject interesting, too.
Roger
A&P/IA, EAA Tech Counselor
KCHD |
Kellym
Posted: Sun Aug 23, 2009 3:13 pm Post subject: LOP (Lean of Peak) Injector Tuning |
Deems, if you get a stumble when first cylinder reaches peak you may
need some injector matching. While I may sense a hint of roughness as I
get near the last cylinder to peak, there is no stumble and continue to
run fine until it wants to quit near 70 LOP.
Deems Davis wrote:
question:
experiencing.
Deems Davis N519PJ
KCHD |
Kellym
Posted: Sun Aug 23, 2009 3:21 pm Post subject: LOP (Lean of Peak) Injector Tuning |
Hi Bill,
LOP fuel economy is only one part of the picture, and is NOT the main
reason to do it. Your engine will run cleaner, use less oil and last
longer running LOP. It causes the flame to burn slower(like higher
octane) giving a flatter pressure pulse to the piston, so that the peak
pressure is less, but the average work is close to same. If you are
below 7500(approx) you can add throttle to make up for lost power. As
long as you are LOP, power =14.9 * gal/hr. So 10gph=149hp. (57%)
75% then = 13.1 gph, if, and only if, you are running LOP. So if you can
find an altitude where you can go LOP and then adjust throttle for 13.1
gph, you should see somewhere around 190mph. Of course once you are high
enough that you are at WOT and less than 13.1 your power is less and
speed will be less. I typically give up 5-7kts to fly LOP, which is
okay as long as I am not fighting a headwind.
Bill DeRouchey wrote:
[quote] These are only two datapoints. What are others achieving? And please
efficiency.
What am I missing?
Bill DeRouchey
N939SB
<http://us.mc344.mail.yahoo.com/mc/compose?to=deemsdavis(at)cox.net>>
question:
Deems Davis N519PJ
gary wrote:
<http://us.mc344.mail.yahoo.com/mc/compose?to=speckter(at)comcast.net>>
mentions 2" but I
seen much
> Gary Specketer
KCHD |
Dick Sipp
Posted: Sun Aug 23, 2009 5:51 pm Post subject: LOP (Lean of Peak) Injector Tuning |
There are limits to "oversquare" operation on the power charts in the
Lycoming operators manual. They vary with all the other engine parameters
but
the limits are higher than one would probably guess, several inches MP over
RPM in hundreds in most cases. These are the hard to read two page charts
and the limit is just a line and is easy to miss.
My normal cruise is 55-65% power, 10.5-11.5 GPH and 160-165 KTAS.
Dick Sipp
Tim Olson
Posted: Sun Aug 23, 2009 5:55 pm Post subject: LOP (Lean of Peak) Injector Tuning |
Bill,
Regarding the speeds, I don't know why Dave was only getting 164.5
statute mph, but my LOP cruise is typically way better than that,
which is about 143kts, right? If I am way lean of peak, and/or
very heavy loaded, I MAY get slowed down to 155-156kts TAS, but
on plenty of trips I'm seeing speeds of 164-166kts at LOP cruise.
If I fly ROP, I'd say most commonly I'll see 173-175kts, sometimes
slower. I've found that between leaning variations, turbulence,
altitudes flown, and loadings, that the speed can be all over the
map, but I don't know that I've ever really seen constant enroute
cruise figures of less than 152kts on my trips. So if I am
getting, say 189-190 statue mph on many flights, and I'm generally
burning 9.5-10.5 gph at my most commonly flown altitudes,
I'm probably pushing right up near that same 19.1 statue mpg
on many flights. There are times I'm a bit less, but loadings
and the other factors don't always duplicate themselves. I'll
tell you what though, there's no way that I'm not getting
better efficiency than someone flying ROP. As Kelly pointed
out, it's the temps, the cleanness, and all sorts of other
things that are benefits too. I'd say that you will usually
lose 6-10kts depending on many factors, such as how far you
lean past peak. I usually just go for 25 LOP on the last
cyl. to peak.
Regarding flying ROP or at peak, like you are talking about,
I tend to agree that if you're way down in power like at
65%, you're probably not going to hurt anything too bad.
But, for those who are running 50-100 ROP, you probably
want to do a bit of studying up. I don't have the numbers
committed to memory, but there is a window at higher power
settings where you really don't want to stay, and I
think in order to stay out of it you really have to
either fly WAY ROP, or go LOP. Again, don't quote me,
but if you venture over 75% power, I'd avoid that range
from maybe 125 to 0 ROP. (Can someone verify that? I've got
docs but I'm not going to dig them up right this minute)
So I'm not saying you're doing anything wrong, at the
lower power levels you can get away with anything. But,
I think you picked a pretty lowball datapoint from David
if you're going to use his 164.5smph. Scott Schmidt
and I both just flew together for 3.75 hours running
LOP and we blew that speed away by at least 10kts
for the whole trip, on something like 9.5 gph. He was
lighter loaded than me and burned about 2 gallons less
over the entire leg.
So the point is, I don't think most people will give up enough
speed to worry about it a whole lot.
[quote] I believe tuning the injector nozzles will create a smoother running
efficiency.
What am I missing?
Bill DeRouchey
N939SB
question:
Deems Davis N519PJ
mentions 2" but I
seen much
> Gary Specketer
dlm46007(at)cox.net Guest
Posted: Sun Aug 23, 2009 6:19 pm Post subject: LOP (Lean of Peak) Injector Tuning |
I was not using WOT at 10000 MSL. DA was 14000+. I don't know the weight but
we had OSH baggage and camping gear. I typically get about 150KTAS at about
8.5-9 gph. IIRC TAS is affected about 2 mph per 100 pounds gross weight
change. My numbers were from pictures just after departing OSH which would
mean higher gross weight rather than later in the flight. 36 gals burned in
the four hour flight to Tulsa after an OSH taxi and number 6 IFR departure
off of R09. After having flown for so many years at slower ground speeds
150KTAS GS or better seems enough. Of course if headwinds are involved I may
push the power lever forward but avoiding a fuel stop also figures into the
calculation.
Posted: Tue Aug 25, 2009 1:12 pm Post subject: LOP (Lean of Peak) Injector Tuning |
Hi Tim-
If I dissect the trip with you and Scott Schmidt you were flying at 14% under max (176.5/205smph) at 9.5gph which yields 18.5smpg. This is the same efficiency as David flying 20% under with reduced power. Not much different than the 19.1smph that I reported. The difference could easily be explained by atmospherics or loading.
My interest is cross country efficiency and I thought there was a significant miles per gallon increase with slowing the plane down and running LOP. My original thought was to collect data points from everyone and plot airspeed percent reduction vs the miles per gallon at LOP. We know when running ROP the speed increases little and the consumption lots. I made a somewhat speed run recently at 8000ft/DA 10425, WOT, 2400rpm, lean 25degF ROP, 200mph TAS, 13.6gph. A 3% drop in speed yielded 14.7smpg.
With still just a small amount of data it would seem that right at peak EGT is the maximum fuel efficiency/airspeed optimum and the fuel efficiency remains (or drops slightly) as you lean into LOP territory.
I ran into Scott on a grass strip in the middle of Idaho. He has a beautiful aircraft.
This is getting too far from the theme of injector tuning so I'll drop off but may bring up efficiency and prop settings at a later date.
Bill DeRouchey
N939SB
Date: Sunday, August 23, 2009, 6:53 PM
--> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com>
Bill,
cyl. to peak.
[quote] I believe tuning the injector nozzles will create a smoother running engine and that in itself has value. However, I have been mystified during these conversations as to the value of running LOP vs fuel economy. There was never enough data in the emails to get the whole picture. The question I always had was how much speed are you willing to loose to gain how much fuel efficiency?
What am I missing?
Bill DeRouchey
N939SB
question:
Deems Davis N519PJ
mentions 2" but I
seen much
> Gary Specketer
Posted: Tue Aug 25, 2009 2:12 pm Post subject: LOP (Lean of Peak) Injector Tuning |
Bill, please continue to gather data ..... for those of us that still
dream of a flying airplane. It's my understanding that LOP has
significant savings. IMHO, the data points should contain your numbers
below plus MP. I'd also be curious what your CHTs and EGTs are. I
think the -10 can do better with some attention to cooling drag.
Linn
do not archive.
beautiful aircraft.
Bill DeRouchey
N939SB
Posted: Tue Aug 25, 2009 4:40 pm Post subject: LOP (Lean of Peak) Injector Tuning |
Great explanation Kelly, THANKS.
Marcus
