ianxbrown
Posted: Sun Aug 30, 2009 6:50 am Post subject: Transmit noise |
I'd like to offer two small ideas since they both seem to make a big difference in my aircraft:
1. The headset manufacturer says put the mike 1/8" from your mouth. That's pretty close, and the further away it is the more other noises can be heard.
2. I noticed most of my transmit noise went away if I unplugged the second headset, or switched the intercom to "isolate" even though the second PTT wasn't pushed. Not sure why that is, or whether it was just noise in my headset that wasn't actually being transmitted.
Ian Brown
Bromont
Quebec, RV-9A
Posted: Sun Aug 30, 2009 8:19 am Post subject: Transmit noise |
At 09:45 AM 8/30/2009, you wrote:
| Quote: | I'd like to offer two small ideas since they both seem to make a big
Sure. This is typical of any noise canceling mic.
The term noise cancelling is mis-leading. Microphones
cannot differentiate between "noise" and "good stuff."
Depending on their quality, they may do a fair job of
differentiating between near-field sounds (your voice)
and far-field sounds (noise). The further your voice
moves away from the microphone, the less it looks like
good stuff and the more it looks like noise.
| Quote: | 2. I noticed most of my transmit noise went away if I unplugged the
Aha! TWO microphones that are tied together without
benefit of separate voice-operated switching. These
systems suffer full-time bombardment of TWICE the
noise when only one person is talking. This
causes you to tighten squelch controls to silence the
extra noise and requires that voices be louder (or
microphone half way down your throat) in order that
the tighter squelch be accommodated.
I'm pretty sure that 90% of your problem arises from
the combination of headsets and your audio system's
handling of microphone signals. It is unlikely that
you can achieve much better results without replacing
the intercom, headsets or both.
You're not alone in believing that stuff designed
for "aircraft" is suited for cockpits with essentially
open-air noise levels. I'm thinking that intercoms
designed for mounting in helmets of motor cycles may
be better designed for this task.
( -Thomas Paine 1776- )
