Posted: Sun Aug 30, 2009 12:44 am Post subject: Balun for VOR antenna |
Bob and all,
While helping a friend wiring his airplane, I stumbled on the
instruction leaflet for his RA-Miller VOR antenna. It calls for a
specific built-in balun coax.
My intention was to follow the instructions in
http://www.aeroelectric.com/articles/BALUN/Balun_Fabrication.html, but
the coax already installed and bundled in the fuselage is RG 58.
To avoid crawling into the fuselage and doing everything again, is it
doable to keep the RG 58, and WHEN and IF a balun is required, to add a
portion of RG 400 with the balun via a pair of BNC connectors ?
Thanks in advance,
Best regards,
Gilles
http://contrails.free.fr
Posted: Sun Aug 30, 2009 8:07 am Post subject: Balun for VOR antenna |
At 03:32 AM 8/30/2009, you wrote:
<Gilles.Thesee(at)ac-grenoble.fr>
Bob and all,
but the coax already installed and bundled in the fuselage is RG 58.
it doable to keep the RG 58, and WHEN and IF a balun is required, to
add a portion of RG 400 with the balun via a pair of BNC connectors ?
It is never "required". Thousands of airplanes
were built in the 50's and 60's where the coax
feedline to a VOR antenna "whiskers" were simply
attached to the two antenna elements: center
conductor to on, shield to the other. This is
depicted on 'Connection drawings in the chapter
on antennas.
If I interpret the words describing the RA Miller
AV12 antenna at:
http://www.aircraftspruce.com/catalog/avpages/av12L_ant.php
it says that the balun is "integral to the coax supplied".
I don't see how this is done in the data supplied.
However, you're not on shaky ground to simply install
per manufacturer's instructions using cable supplied. While
not necessarily the best we know how to do, its performance
will be entirely satisfactory.
( -Thomas Paine 1776- )
Posted: Sun Aug 30, 2009 11:44 am Post subject: Balun for VOR antenna |
<nuckolls.bob(at)aeroelectric.com>
Thank you for your quick and comprehensive answer.
| Quote: | It is never "required". Thousands of airplanes
This is what I did with RG 58.
The problem is, the antenna was purchased with no cable.
Thanks again,
Best regards,
Gilles
