Possums
Posted: Thu Sep 03, 2009 8:21 pm Post subject: Tail Wire Tangs Breaking And other Tail Brace Issue Contin |
At 11:15 PM 9/3/2009, you wrote:
Given the recent very close call by one of our fellow Kolb flyers,
this issue needs to be brought to everyones attention.-snip-
In professional aviation and the airlines, the absence of accidents
does not mean that there is not a large danger. Reports of
problems, and many near accidents is regarded as an accident waiting
to happen, and these problems are fixed before people get
killed. We have a pattern like this developing with our Kolb Tail wires.
I would defer to Dennis as the ultimate authority on any of the
changes the we "think" might improve the original structural design.
If you change/strengthen one thing - you weaken another. You just
move the problem to another area. I only know
of one person who was willing to tear the wings off of a Kolb in
flight - on purpose (not with sandbags on the ground) and
trust a chute to carry him down. This was done to find the weak link
in the design. The "weak link" was fixed years ago and
by weak - I mean more G's than you might ever do..
Most of the stuff I have done is cosmetic or just for looks/comfort.
_________________ Possum |
flykolb(at)pa.net Guest
Posted: Fri Sep 04, 2009 4:25 am Post subject: Tail Wire Tangs Breaking And other Tail Brace Issue Contin |
Everyone,
I really hope, for all your sakes, that I am not the ultimate authority on
this as I have been out of the loop on this stuff for about 10 years - but I
can perhaps add a little bit of perspective. The information exchange here
is awesome and I have learned something I did not know and that was the
breaking of the 4-hole tangs on the Rans.
But, the fact is that adding a turnbuckle does change the dynamics in
several ways (changes are seldom made without consequences), so if you are
going to make a change, realize that your airplane just became MORE
experimental. The turnbuckles do present a real hazard when folding in the
potential to overstress the tang. Plus it makes it very easy to
over-tension the wires which places further stress on the tangs.
I think we are all concerned with safety, but too many times we get too
micro-focused with the safety issues that we can see - not the ones we can't
see. Homer and I both shared a conviction that having turnbuckes on the
tail wires represented a real safety issue in that forgetting to safety wire
a turnbuckle is something very easy to do. So, for that and other reasons
we felt they represented a real safety issue. All our conversations with
Kolb builders over the years has only strengthened this conviction - it is
so easy to overlook something when the airplane gives the appearance of
being fully assembled. Most of us are amateur builders and mechanics and we
easily forget little details like safety pins, safety wire, lock nuts, etc.
but us professionals forget too. Ask me how I know.
If I were in the business today, I would probably continue with a 4-hole
tang, but it would be a 4130 tang made just a little thicker - depending
upon application. Originally we did not use the 4-hole tang or turnbuckles
- nothing is really needed. But the adjustments make life easier.
I would still not use turnbuckles for the reasons I previously mentioned in
an earlier email and above. But I did add double wires to the Slingshot
from the beginning because I felt they were needed for the higher speeds the
SS was capable of going. (I also added a significant internal brace (from
the wire attach point back to the inside corner of the stabilizer) to
properly handle the inward loads imposed by the wire on the leading edge
tube.)
I don't know all the reasons why other manufacturers may use double wires on
the tail, but I do know the major reason - their tail design requires it -
it is not optional for them. With a rectangular tail one cannot say that
they have double tail wires for safety - the design requires it. The light
weight tail structure is not torsionally stiff enough to be held by only one
set of wires. I can further guesstimate that many times this rectangular
shape is chosen not for aerodynamics - but rather for manufacturing ease.
Many of these tails are just a series of bends in a tube. This is much
easier, faster and less expensive than the 3-separate tubes the Kolb uses
that must be gusseted and riveted at every corner.
Homer has always used the triangular plan form on the tail because it will
not stall nearly as easily as a rectangular one will. So in Homer's mind
aerodynamics (shape) is a safety issue. Probably not many on the list see
tail planform shape as a safety issue - but Homer did.
I noticed on the photo of the tail, that another change has been introduced:
the curved leading edge of the horizontal stabilizer - and I have seen these
before too. This type design, while not being rectangular - it has
definitely been taken out of the triangular scenario with its direct load
paths. So if one wants a curved leading edge, I would say should have a
double set of wires - depends upon degree of curvature.
I really hope the group can continue to operate in a civil manner - so much
these days is becoming polarized where someone who has a different opinion
is vilified. This is unfortunate because I don't think anyone of us has a
lock on all the knowledge - so we need to share our little pieces of the
puzzle so we can all see the big picture and hopefully fly more safely.
Dennis
JetPilot
Posted: Sat Sep 05, 2009 7:02 am Post subject: Re: Tail Wire Tangs Breaking And other Tail Brace Issue Co |
| Possums wrote: | At 11:15 PM 9/3/2009, you wrote:
I only know
Possums,
You plane does look good, but some of your improvements are not cosmetic You say you mods were done for " looks/comfort ".... Are you suggesting that you put two sets of tail bracing wires on for looks ? Or that having two sets of tail wires somehow make your plane more comfortable ? You did a very nice job on your Kolb, it is disappointing to see you join in on the recent ugliness with your last post, and that you would even downplay your own improvements in in your kolb for the sake of fitting in with a few people that are intent on discrediting anything I post. You have done some really nice things to your Kolb, to downplay them to " Fit In " does a disservice to yourself and those that might think about similar improvements to their planes.
Mike
Kolb MK-III Xtra, 912-S |
