Doug Gray
Joined: 10 Jan 2006 Posts: 112 Location: Sydney, Australia
Posted: Sun Sep 06, 2009 10:52 pm Post subject: Hand propping a fuel injected 320 - possible? |
Folks,
I am considering converting my O-320 to an IO-320 with the Precision
system and had a thought about hand starting - perhaps it is not
possible to swing the prop for a start like one can with a carby.
I expect the most likely reason to swing the prop is a flat battery - in
which case priming would not be possible so my gut feeling is that it
would be next to impossible to make an engine start under these
circumstances.
Any advice?
We have many very isolated airfields in this country and being stranded
can be a major risk.
Doug Gray
Sydney,
Australia
Gary.A.Sobek
Posted: Mon Sep 07, 2009 2:20 am Post subject: Hand propping a fuel injected 320 - possible? |
IF you can PRIME the system C it should be just as easy to start. The carb has fuel in the float bowl and pulling the blade through gets the air fuel mixture into the cylinder to be ignited when you switch the mag on. As long as you can run the fuel pump to get fuel in the system to the injectors C it will hand prop just as easy as the carb. No fuel to the injectors C no start.
I have helped hand prop a FI 360 (180 HP) once so know it can be down. The 360 is much harder to hand prop than the 320.
Gary A. Sobek
"My Sanity" RV-6 N157GS O-320 Hartzell C
2 C296+ Flying Hours So. CA C USA
| Quote: | Subject: RV-List: Hand propping a fuel injected 320 - possible?
To: rv-list(at)matronics.com
Date: Mon C 7 Sep 2009 16:45:32 +1000
--> RV-List message posted by: Doug Gray <dgra1233(at)bigpond.net.au>
Folks C
circumstances.
Any advice?
Doug Gray
Sydney C
> Archive Search & Download C 7-Day Browse C Chat C FAQ C
&g=====================
Windows Live: Keep your friends up to date with what you do online. Find out more.
n8zg(at)mchsi.com Guest
Posted: Mon Sep 07, 2009 3:39 am Post subject: Hand propping a fuel injected 320 - possible? |
Doug -
Unless it's completely dead, a battery that won't turn the engine over
probably has enough residual energy to run the fuel pump for priming.
Or you could provide for a connection directly to the fuel pump for a small
emergency battery. An 8-slot AA-size battery holder from your local Radio
Shack-equivalent connected directly to the pump should be more than adequate
for priming (and serves double duty as neat, secure storage for the extra
batteries for your hand-held radio and flashlight).
neal
Folks,
circumstances.
Any advice?
Doug Gray
Sydney,
Australia
